05-14-2020, 01:16 AM | #31 | |
05-14-2020, 10:19 AM | #32 |
I dont think so. I have a Mikuni clone and ordered Mikuni jets from jets r us from a link provided here on the forum.
I switched out the main jet already and those numbers matched up to what you would expect. I can see the hole is clearly way bigger on the pilot jet that is labeled 42. So confused. Edit: Posted before I saw MD's reply. Will try out the 27.5 for a while and see how it goes. Its an official mikuni. The bike was noticeably more quiet when idling. My girlfriend even made a comment about it. But if I blipped the throttle it was stalling out. It got better as it warmed up |
05-14-2020, 02:14 PM | #33 | |
The 27.5 idle mixture for me ended up being between 1 and 1 1/4 turns out. The 25 was a bit more than 1 1/2 turns out, close to 1 3/4
09-07-2020, 01:45 PM | #34 |
Need Help
Im new to riding I got a hawk 250 as well. I live in florida and i got a mikuni carb with 110 jet on it and im still having troubles with the choke. It only stays on with the choke and as soon as i turn the choke off it turns off any help on this?
09-08-2020, 09:42 AM | #35 | |
Second, what size pilot jet are you using and how many turns out on the mix screw? Genuine Mikuni or the clone? Your pilot circuit is not right.. |
05-03-2021, 05:29 PM | #36 |
smoke out exhaust
i know this an old thread but i could really use some help.
i live in florida and have the mikuni carb with new exhaust and pod air filter. screw is turned out 1 1/2 main is 115 pilot is 27.5 it idles a little rough at 15-1600 RPMs it smokes a little at idle and when i rev it up the smoke seems to go away. i've done the valve adjustments too should i try to go to a 25 pilot? |
05-03-2021, 10:16 PM | #37 |
Is there a chart for altitude adjustments? I’m at 2300 in high desert... Mikuni clone.
12-01-2021, 08:13 PM | #38 |
MYK VM26 30mm Carb Carburetor PZ30 200cc 250cc for Mikuni
How turns out should I start with the fuel adjustment screw the carb has a 110 main jet on 2 Noch needle jet
08-12-2023, 01:26 PM | #39 |
Hawk 250 pilot jet/needle problems
I have a 2022 hawk 250 with that bogs down at quarter throttle and idles rough after warming up. I have a stock carb with 40 pilot and 104 main with the air screw 1.5 turns out and the needle on the second clip. If i move the needle to the first clip the whole throttle runs lean and if i move it to the third clip the engine rpms instanly go way too high. If i turn the air screw out the rpms go to high again and if i tighten if the bogging at quater throttle gets worse.
My mods that affect the mixture: Nibbi 48mm air cone filter Full jfg racing exhaust system Ac racing cdi box(not sure if that affects the air/fuel mixture) If anybody has suggestions let me know please |
