Hi! Greetings from México!! Need help!
Hello!
My name is Daniel. I currently live in Baja California, México and I just recently bought a Vento Motorcycle.. The model is the "GT-250" and I kinda believe this shares a lot parts and design elements with the Hawk 250, As I am not 100% sure about it I wanted to ask help from you guys regarding this bike. My main concern right now is that I need to adjust my front shocks somehow, I am no motorcycle expert but I can get by with a good guide or reference but I looked around and did not found any info regarding these specific shocks, Visually I think they are the same from the Hawk 250 DLX? I need help tuning them out for my weight as I am constantly bottoming them out in big pot holes or hard braking. I am adding the pictures of my bike for reference, Also a facebook member recently disassembled his shock for repairs but made no guide as to how to do or tune it so I hope this helps identify the shock absorber. Marketing photo: ![]() Real pictures: ![]() ![]() ![]() ![]() Forks: ![]() ![]() Hope you guys can help me out! |
Looking at the way those forks are constructed, they are just a damping rod style fork turned upside down, nothing too fancy.
I do believe the Bashan Storm and Brozz forks are very similar to those, so the guys that own those bikes might be able to offer some insight on fluid levels, but you can always experiment with heavier weight fork oil to help increase the damping a little bit. Another thing you can look into is setting an appropriate amount of rider sag by making some preload spacers for the springs. The above two things help us Hawk guys with our skinny traditional forks. - One Daniel to another. Nice bike! Reminds me a bit of some of the bigger Zongshen ADV bikes.
Thank you very much for the information Daniel!.
Could you happen to know which chinese manufacturer built this bike? I havent seen something similar from the chinese makers. I heard a lot of Zongshen or Lifen? But the engines looks awfully similar to me for Lifen Engines. I havent build or disassembled a fork in my life so if you know a thread or video I might give a look or how to search for info about these types of forks? Ive read "USD Forks" but I dont know what that means or if it applies to my forks. I think the Zongshen ADV bikes are sold here under the "Italika" brand as the V200 and VX250. |
Unfortunately I couldn't begin to tell you who built it. I have never seen that specific bike before in the U.S. There is a lot more variety of bikes sold south of the Border than we get, in terms of quality, options, engines, etc. The Laws in the U.S. make it far more difficult for importers. There are a bunch of bikes I have seen that I would love to have that I can't get.
I don't know of any video made for those specific forks, but I remember a thread for a Bashan Storm where he took the forks apart and delved in and it may help you figure out disassembly. http://www.chinariders.net/showthread.php?t=23687 Other than that, some basics of fork maintenance and service are pretty universal. Watching some youtube videos on the subject will at least prepare you for it to a certain degree.
Try adding about 10cc of fork oil to each fork leg. This method does not slow down the first portion of the fork stroke, only the last portion so you get good grip in corners but on bigger bumps/jumps it stops the bottoming.
Depending on your riding style and weight 5cc may be enough so you may want to start there, use a turkey baster to add or remove the oil, many of them have measurements on them
As you travel down the road of life, keep your eye upon the donut, not upon the hole ![]() 2020 Lifan X-Pect 200efi 2005 Harley Davidson Sportster XL1200R |
#6 | |
#7 | |
Yeah I also noticed the imported bikes over the USA have catalytic converters and the carburetor is pretty much sealed! This bike has nothing of that, Exhaust is free flowing and the carb has the philips bolts and air mix needle as well for full disassembly and tuning although I dont know if the Mikuni jets will fit bolt on. Thank you very much for the help! Much appreciated. |
#8 | |
Ohh sweet! I will check it out tomorrow.
#10 | |
that a really nice looking bike, what does something like that cost?
Due to rate exchanges it roughly went for 2700USD.
It isn't the cheapest model by any stretch, its the 2nd most expensive model from Vento Motorcycles and the only 250cc "Aventure" bike at this price point sold in México. The GT-250 includes: -Full LED Lightning. -Alarm with 2x FOBs (You can turn on the lights remotely for visibility). -2x Auxiliary LED fog lights, Pre wired to low beam lights. -Hazard lights function -Crash guards -Pre-load adjustable rear monoshock -Supposedly "17HP" engine. -5 Speed trans -USB Charger -4 Gal gas tank (280miles range!) -2x 38L Plastic waterproof and lockable luggage boxes with easy to remove mounts. -56T Sprocket using 17T Pinion. |
#12 | |
The CG engines respond really well to tuning, you probably don't have the exhaust catalyst that we have so you won't need a new pipe. Raising the compression and opening up the exhaust port works well also. Advancing the timing by 4 degrees with an offset key and finally a longer duration cam brings them up to what feels like 21-22BHP. I've done all these mods to my bike and it will easily get up to 75mph
#13 | |
#14 | |
