Old 01-22-2019, 05:34 PM   #1
Jeff46   Jeff46 is offline
Help dr125 exaust
Need a new exaust for a baja motorsports dirt runner 125cc anybody have a link or know what will fit ? Or should I just bust out my crappy harbor freight flux core
Old 01-23-2019, 11:39 AM   #2
Your original exhaust looks to be intact; is it cracked? Maybe an old XR125 exhaust would do the trick.
I suspect that an old XR185/200 exhaust could be modified to work (not the XR200R version). The exhaust systems used on current Honda-cloned China bikes could also be modified to fit, like the Hawk.
Old 01-23-2019, 03:28 PM   #3
Thanks . The mid pipe bracket that goes to the frame cracked compleaty off ( I have a fix for that ) and the pipe to muffler weld cracked compleaty around. Now it's a slip on lol
Old 01-24-2019, 11:20 AM   #4
Since you can fix the bracket, maybe you'd like to just grab a cheap slip-on and call it a win.
Old 01-24-2019, 03:55 PM   #5
That's what I am thinking. How do I attach the slip on exaust the one I am looking at looks like it has set screws. How does it seal. The bracket I'm going to weld if I can get my welder back if it still works I loaned it to a buddy a few years ago. If not I will make a stand off and use High temperature clamp
Old 01-25-2019, 01:35 PM   #6
Some slip-ons clamp on, some are retained with springs and some use set screws. Before you go that direction, what's wrong with the existing muffler?
Old 01-26-2019, 10:51 PM   #7
The weld cracked compleaty around the pipe to muffler joint the pipe is still goes into the muffler but it leaks a lot and is louder than it was before. Also the mid pipe bracket to the frame cracked in 2 .plus the whole exaust is pretty rusty so I can take the Opportunity To clean it and paint it with some high temp paint.
Old 04-05-2021, 06:27 PM   #8
scanterbury   scanterbury is offline
i have the same problem and i wanted to know what size slip on might work if i cut the old muffler off the person i bought it from took the baffle out and cleaned all the packing out and now there's a ring finger sized hole in the muffler near the front where its welded
Old 04-06-2021, 03:10 PM   #9
rideMI   rideMI is offline
I have a few Vipers and have the same problem. Just pull out the crappy welder, or find someone like Weldangrind
Old 04-06-2021, 05:54 PM   #10
The exhaust bends are not the same
Viper
