03-20-2021, 08:54 PM | #1 |
Gio (taotao) 125D
I just bought one of these and the customer service is awful and no assembly instructions. In one of the ziplock bags there was 4 smaller bolts and nylon insert nuts that held on the top rack and 2 larger bolts with no nuts and I have no idea where they go. Any ideas?
03-20-2021, 11:39 PM | #2 |
Member flashlightboy is a Gio dealer ,he might be able to help .
03-21-2021, 03:42 PM | #3 |
Pics of what you've built and what you have left would be helpful.
-J |
03-22-2021, 06:01 PM | #4 |
I had to find a youtube video when i assembled mine. If you want my personal opinion, if you're still in your warrantee window and eligible for returns send it back and spend the money on something you're not going to constantly have to work on
03-23-2021, 09:22 PM | #5 |
parts..
hello... yes please ask me your questions will help you... for assembly ... there is lots on youtube... how to assemble 125 D atv... and others ... it is all the same... some videos are better... but you should catch the drift... plus how to change oil.. videos.. but message me with your problem or questions..... wiring diaphram is in th e book... or google it ... all over the web... do not go by wire colours.... go by where they run to and from
03-26-2021, 11:13 AM | #6 |
Lash light boy I sent you a PM... the manual says I can take out a restrictor to make it faster is that n the intake filter(looks like a ball on the throttle body) or in the exhaust? Thanks
04-03-2021, 01:13 PM | #7 |
my $02. worth...
Any "restrictor" will be in the exhaust. That "ball" on the intake is a hopeless airbox with only a useless screen over the carb's intake. It does NOTHING to protect your carb/engine from dirt. Take it off, measure the diameter of the carb's intake and get, at least, one of those cheapo cone shaped racy colored chromed filters to fit. (better, get a foam Uni filter) There will be a hose in the airbox (to vent the crankcase back into the intake.) Whatever... G'luck!
Tao Tao Raptor 200 Tao Tao DB 110 (Princess Auto) Mini-Bike Kit |
04-03-2021, 05:09 PM | #8 |
I think you are talking about the max throttle adjustment screw. It's on the handlebars beside the front brake lever.
