Old 04-01-2021, 03:28 PM   #1
KenTaoyan   KenTaoyan is offline
KenTaoyan's Avatar
front sprocket bolts
Another mistake I made upgrading my hawk was I tightened the bolts down too much on the front sprocket. The stock bolts are cheap and soft for this application. (in my opinion (which does not constitute as a viable opinion)) I found replacements at a local Lowes that are almost the same M6-1.00 x 12mm. (1 mm longer) but they look just as soft.
I have looked and searched for a proper torque spec on these and have not found it (other than a Youtube vid where the guy says, "yup, dat's good N tight")
also has anyone sourced a better grade bolt? Seems like that front sprocket needs something better to rely on. Allen head instead of 10mm hex? (and of course Loctite.)
~ toys in the cave (in the order of addition)
81 Honda XL185s {work in progress}
2018 QIYI Coolster 3150CXC 150cc Quad
2019 QIYI Coolster 125cc Quad
2021 Roughhouse 50 (neat little scooter for the wife)
2022 QIYI Coolster 3150DX-4
I may not be fast but I am "Half-Fast"
Old 04-01-2021, 04:01 PM   #2
TxTaoRider   TxTaoRider is offline
I never tighten mine down very tight but I use orange locktite. It really just holds that lock plate on.
As an interesting observation, on the 520 chain sprockets, if I buy one that's less than 11t, it comes with a snap ring instead of a lock plate so the chain doesn't ride on the bolt heads. No bolts at all.
2021 Tao Tbr7 - "Lucille"
Mods so far- Brozz swingarm, 21" front rim (Bridgestone Tw302 rear/Dunlop D606 front tires), Digital gauge cluster, pz30b pumper carb, after market hand guards, aftermarket brake and clutch levers, round fold away mirrors, Fly handlebars shortened slightly, 13t front sprocket
2009 Q-link Legacy 250
1982 Suzuki GS1100ES - "Jolene"
Old 04-01-2021, 06:17 PM   #3
I run grade 10.9 metric flanged hex bolts with a lock washer 15mm long threads, and I also put just a dab of 243 loctite on them. Grade A2 or A4 stainless bolts would also work, but can be a bit pricey. As far as torque goes, 12-15lb-ft
bolts, sprocket
