Old 03-28-2021, 04:21 PM   #1
tj4ndirish   tj4ndirish is offline
Tao Tao 125 Coolster Won't start
Hi all,
First post, looking for some help. I have a 2019 Coolster 125 it will not start. The solenoid just clicks. I changed the solenoid and does the same thing. Tapped on the starter, nothing.
Any ideas would be greatly appreciated.
Thanks!
Old 03-30-2021, 01:56 AM   #2
Douglass   Douglass is offline
Douglass's Avatar
How is the battery? I had a battery go bad shortly after getting the new atv.
Old 03-31-2021, 05:36 AM   #3
As Douglass says, check the battery. If that's fine (more than roughly 12.5V) jump the starter relay (solenoid). If it starts, the relay is bad. Report back if it doesn't.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 03-31-2021, 07:33 AM   #4
Also check all battery connections and grounds.
Old 03-31-2021, 09:01 PM   #5
SevereTrauma   SevereTrauma is offline
SevereTrauma's Avatar
Have you run it before? Not to insult you but I was trying to start mine today after a brake pad change and it wouldn't start. Was driving me nuts. Didn't have the brake pulled in enough after adjustments was all my problem was.
Old 04-05-2021, 10:13 PM   #6
Nicthegreat420   Nicthegreat420 is offline
Has anyone gotten back to him and try to see if he’s gotten started yet because if he can’t get it started he might have to bypass Killswitch and jump it that way
