Old 05-22-2008, 02:47 PM   #16
katoranger's Avatar
My idle screw has a knob and I can adjust it while at a stop light.
Raising the idle will help the stalling some, but you are giving signs of being lean so moving the c-clip will most likely solve your problem.
Allen
Old 05-22-2008, 09:53 PM   #17
ambassador   ambassador is offline
My idle screw has a thumb knob like Kato's and it really makes a difference in keeping you bike idleing, I guess it may be hard to tell if you dont know what your listening for, the tachs on these bikes are close but nothing beats adjusting it to the sound of the motor...
Get some tools (METRIC) and drop your C-clip, that should help alot...
06 Lifan 200 GY-5
Old 05-25-2008, 06:10 PM   #18
Komoto250cc   Komoto250cc is offline
Kink in the fuel line
My Komoto 250cc would cut out in a similar way until I changed the fuel line from the carberetor to fuel shut off valve. The original line was cheap and flimsy. It would easily get kinked and starve the motor of fuel. I bought a clear, rigid line and since then it has been running good. Make sure you cut the new line so it won't also kink.
Old 05-25-2008, 07:38 PM   #19
Make sure you have a good fuel line
Make sure the fuel line from the shut off valve to the carberator isn't kinked. To prevent a kink make sure it is the "right length" (trial and error) and is made of rigid tubing. You can buy a new line for 1.00 a ft. at a local bike shop. This solved my problem.
Old 05-25-2008, 08:12 PM   #20
warrior91   warrior91 is offline
Originally Posted by Mavrick
And also, it cut off on me twice again today while I was riding. It seems to want to do it when I begin to slow down after high speeds. This scares me, I don't want this happening once I'm riding around town with other vehicles. It may have just been my fuel though. I don't think I had enough gas. When I bought the bike, the guy decided to put some gas in the tank, so I could get where I needed to go, but for the length he held the gas jug there, I thought he filled it up, but I checked and it's pretty much empty. You think this could be the reason for the cutting off?
I'm still waiting for the answer. What is pretty much empty?
Can you see the hump in the tank? How many km/ miles have you put on since the fuel went in? Was it nice clean gas , or dirty old jug??
'91 Yamaha Warrior- stage 2
'83 Honda ATC 70
'08 Yongjiang 125cc mx (Loncin)
'08 Yongjiang 150cc atv (Jinlong)
Old 05-25-2008, 08:33 PM   #21
Fuel mixture screw? Too lean?
IronFist
The "chain" of command is used for beating spammers.
Old 05-30-2008, 12:38 AM   #22
Is this bike running?
'83 Honda ATC 70
Old 05-30-2008, 12:44 AM   #23
CRidin   CRidin is offline
I think I saw somewhere that he wrecked it?
Old 05-30-2008, 02:39 AM   #24
Mavrick   Mavrick is offline
Send a message via AIM to Mavrick
Sorry, I haven't really had a chance to be on and post or to go into detail when I do post. I did in fact have a wreck and now my doesn't run. I'll need some help with that as soon as I get a chance to elaborate.
Not All Those Who Wander Are Lost
Old 05-30-2008, 05:13 AM   #25
TeamCheap   TeamCheap is offline
Well thats not what we like to hear, someone having a wreck.
It happens though, are you all right?
Old 05-30-2008, 02:13 PM   #26
Did you at least have your free helmet on? Or some boots or at very least some socks? :wink:
I guess the bike ran well enough...or had enough fuel :oops: to wreck.
'83 Honda ATC 70
Old 05-30-2008, 02:35 PM   #27
8O Bubblewrap? 8O
At least he was well enough to get to the computer and type CRASH>......
IronFist
Old 05-30-2008, 03:29 PM   #28
I'm actually hurt and still hurting at this very moment. I think it might be serious enough to go to the ER today. Depends on whether or not this pain in my side subsides.
And yes, I was wearing my free helmet and I believe it saved me a whole lot of injury however inflicting injury at the same time. My neck rolled and the bottom of the helmet was thrusted into my neck.
Old 05-30-2008, 03:46 PM   #29
srreynolds2003   srreynolds2003 is offline
That no way to start off as a motorcycle rider....
What's the old saying pick yourself up, dust your self off and get back on...Hope you get to feeling better...
-2005 Sierra SR200-
Old 05-30-2008, 03:46 PM   #30
AZ200cc   AZ200cc is offline
Did You crack a rib? Hope everything goes ok.
<br />2001 Suzuki DR200SE<br />1997 Suzuki RM250 YIKES<br />1995 Yamaha Breeze 125 daughters<br />1991 Honda XR80r Restored<br />maybe a 2003 Yamaha TTR90
