#31 |
No matter what I do it keeps saying too big. Dont know why.
#32 |
Use an image hosting site like imgbb.com (what I use). You can upload there and then post to the thread using the "Insert image" option in the top tool bar, and then simply copy and past the direct links.
#33 | |
TR
As you travel down the road of life, keep your eye upon the donut, not upon the hole ![]() 2020 Lifan X-Pect 200efi 2005 Harley Davidson Sportster XL1200R |
#34 |
Might try it on a computer if you can. Select the picture, right click, then select resize and "S"
#35 |
That's what I now use, after asking idle purr about posting pics. You can resize the pictures right on the sight by hitting the edit (pencil icon) .All you need to do is set the width at 750, submit, upload, and copy the bb medium code, and paste them in your post on this forum. I know that you already know how MegaDan, but I figured that it may help those ,who like me, are not real good at computers, and phones.
#36 |
Magician X-pect riding
First good day for riding in since I think winter began. Least I could get out in. Did some break in on the X-pect 30 miles and that felt so good I had to take Magi out and do the same course! These bikes remind me of each other, not how they look but how they ride! CG strong, ride hard!
#38 |
Nice looking bike! Good job on the PIX and the exhaust. You should do a right up on how you did that exhaust!
#40 |
I ride in a few different areas... pipeline ways, abandoned frontage roads, future home construction sites, etc. The storm has comfortable ergonomics and easy controls. The Tusk DSport rear tire makes trail riding easier!
Rutted dry clay treachery! Entrance to the trail- it is a heads-up! |
#41 | |
Thanks. I cut the muffler mounting bracket off the frame and drilled a new hole in the aluminum mounting tab on the muffler. There was a pre-existing hole near the original muffler mount that I cut off that lined up pretty well with the newly drilled muffler mounting tab. As you can see in the pic, I cut out the plastic to allow the muffler to fit underneath everything. I hammered a little flat spot on the pipe for clutch cable clearance and used a little heat wrap which I really don't think I needed. The biggest pain was drilling the hole in the stainless for the O2 sensor bung. I drilled a small hole with a bit and then enlarged it with a rubber wheel in a dremel. I cleaned up the weld a little with this as well. The whole thing fit with very little "persuasion." I also hacked off the rear fender. |
#42 |
Q, in all her glory.
#43 |
My Black Beauty.
#44 |
There's just something so damn lovable about these bikes. It's like that girlfriend in high school who may have not been the prettiest, or the most popular....but they always tried the hardest and never let you down!
#45 | |
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-05-2022 at 11:41 AM. |
