Old 02-17-2021, 08:25 PM   #16
Mrmazak   Mrmazak is offline
Originally Posted by jatgm1 View Post
Where can I just buy a muffler that includes one that will slip on....
Found a slip on "muffler" with removable spund killer/db killer.
It comes with a 38mm to 51mm adapter.
The common aftermarket exhaust I. Find most people here using comes with 38mm mid-pipe.
So this slip-on should work with it.
Just one example.of many such adaptors available.
https://www.amazon.com/dp/B074CVHHGC...ing=UTF8&psc=1
And if you keep looking you can find this slip on sound baffel that should work to quiet down the ebay exhaust.
https://www.amazon.com/dp/B07FDZB1S5...V476MWJSPXJ4M6
Old 02-19-2021, 01:41 PM   #17
jatgm1   jatgm1 is offline
If theirs no premuffled and prebaffled 38mm exhaust under 100 $ then my neighbors can go eat one tbh irdc.
Old 02-19-2021, 04:26 PM   #18
I just don't get the resistance to the quiet inserts I mentioned before. 30 bucks, and it's literally only 3 bolts to remove and re-install with a 3mm allen wrench.
Old 02-20-2021, 04:52 PM   #19
I can't figure out if it comes with the clamp on mount. I contacted the seller to ask. That looks about perfect if it doesn't fall apart.
Old 02-20-2021, 04:52 PM   #20
Because then I'll have to buy another muffler too if I want to be able to switch it out by switching the mufflers.
Old 02-20-2021, 06:36 PM   #21
Or simply use a 3mm allen wrench and take the 5 minutes or less to remove or swap out the silencer for the standard size tip.
Old 02-21-2021, 05:12 PM   #22
Its easier to swap mufflers. It's held on by a pin. Literally takes like 15 seconds to swap. Pull pin. Pull muffler. Put muffler on. Put pin back in. I had to get a bolt with a hole for this to work. This whole bike comes apart in like a few minutes. I want to be able to swap while out. Start at home quiet, pull muffler and replace with one from backpack. Run loud. I I'm not fiddling with a damn baffle.
Old 02-21-2021, 05:56 PM   #23
XLsior   XLsior is offline
XLsior's Avatar
So hang on are you going to be carrying both and swapping mufflers every time you enter and leave your place of residence due to the neighbors? erm that's not as practical as you think.
Honestly id just get a Stainless steel pot scrubber bung the muffler exit get to get around the block, then open the pipes and let loose. whats that about $1 and less than 1min
Old 02-21-2021, 05:59 PM   #24
There's always the old banana in the tailpipe option.. I remember that from Beverly Hills Cop.. joking
In all seriousness yea swapping mufflers will be a super hassle and it sucks you have to worry about it to that point, hopefully whatever option you go with is easy and not much of an inconvenience as is being put upon you
2024 Zuma Storm 150 DLX
2019 Beta 430 RRS
Old 02-21-2021, 07:15 PM   #25
Dude I literally just pull the pin, rotate the muffler like 40 degrees and remove it. Theirs no springs or anything. I tested it. It literally takes about 15 seconds if I'm not in a rush. I could do it with the bike running. I'm tired of my neighbors being passive aggressive assholes so that's basically the plan. I got a bolt of the right size meant for some weird application that requires it have a hole in the threaded end of the bolt so i can just stick a codder pin in it.
Old 02-21-2021, 07:17 PM   #26
I'm like 50 percent sure he is just trying to get me in trouble because he's an old spiteful dick. I mean his Jeep is louder than my bike so idek what he's complaining about. I'm just gonna hot swap them at the stop sign our of ear shot and that's just that
Old 02-21-2021, 07:19 PM   #27
Oh p.s. I have a biden sticker prominently on my bike a car and he has a trump flag. Pretty sure that's the pettyness he's working with.
Old 02-21-2021, 07:24 PM   #28
XLsior's Avatar
the conundrum I see is not doing the swap the issue I have is carrying around 2 mufflers.
Old 02-21-2021, 08:31 PM   #29
Eh. I have a big backpack. Was thinking of putting a bolt on the other side and mounting the non functional one there where people put the taco tubes. Just don't really feel it.
Old 02-21-2021, 09:42 PM   #30
BuffaloChinaRider   BuffaloChinaRider is offline
Like others here said, it just doesn't seem practical..BUT if thats what you want to do and are gonna do, just do it. Have some great gloves too for when the exhaust is hot..because it does get hot quickly. Sucks that you live around neighbors like that.
BuffaloChinaRider on Youtube
Bashan Storm 250 (2018)
Apollo Db-36 Deluxe (2019)
