01-18-2021, 06:53 PM | #1 |
2020 Brozz recon electrical issue
2020 Brozz, less than 80 miles. Had it parked under the carport for a couple of days, went to start it and the battery was cranking slow. Turned the key off and it continued to crank (dash didn't power up, key off). Disconnected battery, charged it and now when I go to hook up the battery (key off/out) starter engages immediately. Anyone had something similar happen?
01-18-2021, 07:20 PM | #2 |
Haven't had that same issue but try disconnecting the remote start and see if that helps
01-18-2021, 08:40 PM | #3 |
Yeah, if it isn't something weird with that stupid remote start they come with, then give the starter solenoid/relay a good thump or two.
01-19-2021, 04:15 AM | #4 |
Thanks for the advice. I'm going to pull that remote start off this evening. I didn't see a sticky for the remote start removal but fairly painless? Thanks again
01-19-2021, 11:16 AM | #5 |
My remote receiver and alarm was right under the seat. I just took it off The seat and separate the device. You can either do that or just don't use the key fob at all. Either way solves the annoying issues.
BuffaloChinaRider on Youtube Bashan Storm 250 (2018) Apollo Db-36 Deluxe (2019) |
01-21-2021, 07:16 PM | #7 |
Ok, went riding today and went shut it off, dash powered off and it stayed running. Choked it out and disconnected battery. Any body wire in a kill switch or ideas?
01-22-2021, 05:35 PM | #8 | |
Go back in , connect the two wires and see if that fixes the problem. Let us know. |
01-28-2021, 03:48 PM | #9 | |
Fixed it! Thanks for the lead!
