12-05-2020, 06:13 PM | #1 |
SAI Delete, Manifold vent popping, Staying Lean no matter what.
Hello fellow China Riders.
So some background... I put in a new Mikuni clone into my Apollo DB36. https://www.amazon.com/exec/obidos/A...im/refuge08-20 I removed the SAI crap, attached a oil catcher and breather filter for the crankcase, and plugged the motor with this https://www.ebay.com/itm/NCY-EGR-BLOCK-OFF-PLATE-FOR-50cc-QMB139-150cc-GY6-MOTORS-/182189030236 I also plugged the manifold vent with some silicone cap I had. The problem.... It was running amazing. Had the spark plug a nice caramel color. Came back in a week, and now no matter what i do, the spark plug is white. I noticed the cap on the manifold is not there anymore, I am also hearing and seeing that the vent lets out a loud burst of air or spark? (it was blue). So the cap probably got blown off. The spark plug is now white, no matter what i do. No matter how rich i turn the fuel screw, it stays white. Question: Could this vent on the manifold be affecting the tuning process? Question: Should i cap this vent on the manifold? Any suggestions on how? Thanks everyone. I took a 5 second video where you can see the bursts coming out of the manifold vent, but i don't know how to upload videos here. I spent like 6 hours trying to get the spark plug caramel again. Would appreciate any help. |
12-05-2020, 06:54 PM | #2 |
Yes, plug the vent on the manifold. You're sucking in too much air. That's why is running so lean.
12-05-2020, 08:03 PM | #3 | |
Should be ok? Or do you have any other suggestions? |
12-06-2020, 01:39 PM | #6 | |
Yup i think i'll go get a vacuum plug. Should be a safe fit. Thank you |
12-07-2020, 12:46 PM | #7 |
I just used a short piece of vacuum hose and stuck a bolt in it to plug it.
