Old 11-09-2020, 01:14 AM   #1
ktbaja   ktbaja is offline
ktbaja's Avatar
2021 TBR7 forks
Hi all ,I have a 2021 TBR7 and before I rode the bike I wanted to change all fluids to better quality and check there capacities.
The attached picture shows the fork spring spacer and fluid volume I pulled out of fork.
The spring is 7/8 diameter and 18'' 1/8 long the spacer is 7'' long.
I read on the board that there is a 15mm spacer on top of springs but mine has a 7'' spacer.
Is Tao getting cheap and using a shorter spring that is requiring a longer spacer?[IMG]
[/IMG]
Old 11-09-2020, 01:21 AM   #2
ktbaja's Avatar
Also here is a pic of the volume of fork oil I pulled out. 5oz (147ml)
I added 7oz (207ml) of 15w oil because I am a large rider.[IMG][/IMG]
Old 11-09-2020, 05:55 AM   #3
TxTaoRider   TxTaoRider is offline
That does seem a little short but I wouldn't worry about it. Some after market spring companies use short springs with long spacers (I've bought Sonic brand for a couple bikes and they are pretty short). In fact I'll bet if you measure the inside and outside diameters, and overall length and contact Sonic with your weight and riding style they'll ship you out some springs pretty cheap
2021 Tao Tbr7 - "Lucille"
Mods so far- Brozz swingarm, 21" front rim (Bridgestone Tw302 rear/Dunlop D606 front tires), Digital gauge cluster, pz30b pumper carb, after market hand guards, aftermarket brake and clutch levers, round fold away mirrors, Fly handlebars shortened slightly, 13t front sprocket
2009 Q-link Legacy 250
1982 Suzuki GS1100ES - "Jolene"
Old 11-09-2020, 06:37 AM   #4
Bruces   Bruces is offline
These bikes are made as cheap as they can for the money ,nothing is top of the line , if they can save a dollar on a cheaper shock that’s what your getting ,should be no surprise that things are changing with the components .
