Old 11-06-2020, 06:19 PM   #1
150 gy6 crank seal
Anyone number t he part number for this seal.... or what model did HONDA call this?? as the parts people say... 150 gy6???? did not know honda made a GY6 motor... they are no help... newer parts people just know fuel injection models... and if it only a few years old... tried to match up at local bearing and seal places... see one on EBAY.. but 4 weeks away.. so if some one could give me info on this ... thanks
ABIBABA ATV ETC
Old 11-06-2020, 09:15 PM   #2
franque   franque is offline
Honda didn't make the gy6. It's an amalgamation of different designs, if I remember correctly. What was the issue of matching it at a bearing supply place? Just measure with calipers and order.
Old 11-07-2020, 04:56 AM   #3
humanbeing's Avatar
http://atvscooterparts.com/pdf-ky/sc...25F-SA25AG.pdf had hints...
Anyways those kit are as
Old 11-08-2020, 12:15 PM   #4
seal
ok.. thanks ... it is for a customer... he would like to get one NOW..... thats why I thought if some one knew the HONDA PART NUMBER... he could get it faster.... I told him to go to bearing shop.... so he phoned.... no they do not really help people on th e phione as much as if you go there... to cross it over... ok... thanks
ABIBABA ATV ETC
Old 11-08-2020, 02:53 PM   #5
Well, if you get measurements, they'll be able to find you something. The only one that might be difficult is the 2 19.8x30x5 seals (but they can still be found on Amazon). The other two are relatively common.
Old 11-08-2020, 02:53 PM   #6
humanbeing's Avatar
According to Taiwanese page https://forum.jorsindo.com/forum.php...=1&tid=2552776 Yamaha 93102-22843 are as 19.8*30*5 ***At ur own risk***
Nitrile (NBR) is the most common type is this application. Fluorocarbon (FKM) aka those "brown thingy" also available IF u tried HARD to find it at the right place...
https://www.ptt.cc/bbs/biker/M.1460098893.A.AEB.html Intresting ?!!! SYM's infamous "brown" to "black" & endless failure ...
