11-06-2020, 05:19 PM | #256 | |
11-06-2020, 06:09 PM | #257 | |
Thank you for considering the trip! |
11-06-2020, 07:27 PM | #258 |
Just had to clean the whole "fuel system" on the champion in preparation for tomorrow.
I have NO idea how to get it to the start point, other than ride it from here... And as we all know from my past posts, that doesn't usually work out too well. (stay tuned) lol Anyhow, as of right now, I'm in the "Definite Maybe" catagory for 9 in the am tomorrow. J (Edit) Heading out at 4:30 to see if I (the bike) can make the trip. Nothing like a trial by fire to test ones metal. (Second Edit) Told y'all so, Made it exactly 6 miles from the house and the bike started chugging, and sputtered out. Won't run without the choke on, won't start if it's warm, Getting ready to post it to CL, Good luck on the rally (?) Last edited by superduder; 11-07-2020 at 07:11 AM. Reason: Additional information |
11-06-2020, 07:56 PM | #259 | |
I was hoping to compare my bike as it was which is bone stock with a stock cfr exhaust system and a replacement carb (with jetting) and a better spark plug. I would have liked to see the difference compared to your bike and Emikrols bike. I did the following: 4 degree timing key (checked the stator bolts while the cover was off (good) Put in the bigger cam with roller followers (i think the same as megadan) Head decked 1mm porting will start happening tomorrow (i can see the exhaust port needs a bit of work and i will just smooth out all the other areas of the head. I have a PWK 30mm smooth bore , flat slide carb (a full jet kit to get it dialed in) plus matching intake manifold and a UNI foam filter waiting to finish it up. I was going to order the big bore kit from the cg300 but put that off for now as it will be a case splitting job with a bore of the area where the bigger sleeve goes in . According to my maths if the big bore kit has the 70mm piston then it will yield 250cc's so i assume the cg300's must have a longer stroke as well to get the displacement up ? Again i wish you guys all the best for tomorrow. |
11-07-2020, 09:37 PM | #260 |
This year's ride is done. It was a fun time for all! It is fairly local to the Phoenix metropolitan area, so I am sure there could be more rides on the same general trails/roads. Musictrek knows many alternate routes, so even with the same starting point, and ending point, there are numerous combinations between. We had 3 Chinese bikes, 1 Japanese, and a Russian.
"They say that life's a carousel, spinning fast you got to ride it well..." TGB Delivery Scooter 150 TMEC 200 Enduro--carcass is sadly rotting in the backyard Last edited by culcune; 11-08-2020 at 02:13 PM. |
11-07-2020, 10:02 PM | #261 | |
11-07-2020, 11:22 PM | #262 |
A Japanese, A Russian, and three Chinese motorcycles walk into a bar...
11-08-2020, 08:29 AM | #264 |
That's the Russian's first round... What are the rest of them going to drink?
11-08-2020, 08:47 AM | #265 |
yup, that was a good time. looking forward to seeing the video.
11-08-2020, 01:10 PM | #266 |
Fun times!
11-09-2020, 04:28 PM | #267 |
Woking on that video. The upload times to youtube is taking over 24 hours. I think I could have drove the video to youtube headquarters quicker!
11-10-2020, 09:37 AM | #268 | |
I do hope you got some Ural footage, and DO NOT have footage of any of my embarrassing moments...
11-10-2020, 12:21 PM | #269 |
Sorry no bathroom break videos
11-10-2020, 12:26 PM | #270 |
Wickenburg ride video 2020 Nov 7th
I need to fire the video editor. Oh wait that’s me. Sorry I left out the DRZ in the title. I got hung up on the Russian and the three Chinas walking into the bar. DRZ went out for sushi. As usual I ran out of battery for the whole ride. I should have plugged in from usb power. It’s a good nap afternoon video to
250, wickenburg |
