10-08-2020, 08:51 PM | #1 |
Tbr7- tt 250 header pipe swap?
I saw a parts list of the tt 250 exhaust, it doesn't have the bulge for a cat that the tbr7- HAWK, and others have. Does it fit? Has anyone tried it? If it does it seems like a better option than gutting the stock pipe, it's 25-30$.I want to get rid of the CAT on my bike, but I'm not looking forward to cutting and pounding it out, plus I don't have a welder, I also heard that the EBAY exhaust kits are noticeably louder, I'm trying to avoid that
Thank you Safe riding Christopher |
10-09-2020, 07:42 AM | #2 |
The header pipe to muffler connection is different. You can buy just the header pipe and use with the stock muffler or any other slip-on muffler you choose. https://www.amazon.com/dp/B07CM45V1H...v_ov_lig_dp_it
10-09-2020, 11:53 AM | #3 | |
Question
10-09-2020, 11:56 AM | #4 |
I've never installed one on my bike. Still running stock gutted header with aftermarket muffler. I would assume it will pass close and most of the CFR230F exhaust systems do on the Hawk and other Chinese dual sports.
10-12-2020, 09:51 AM | #5 |
Aftermarket header exhaust pipe for the TBR7 will require modification to fit and muffler tape and they will wake up the neighbors a bit.
Its part of changing over to the "dark side", accept the mods, tape and noise and you'll be fine. It is for those same reasons that I kept mine stock , or in my opinion, go the route Jerry went and gut the stock pipe for perfect fitment. Last edited by kingofqueenz; 10-12-2020 at 10:50 AM. |
10-12-2020, 07:27 PM | #6 |
Hi king, hi all. I contacted. C.S.C. about the pipe and they said no, it wouldn't fit any other bike, kinda sounded like I was not the first to ask. If it did work they would sell many,many of these. ( think of all the people who went through the process of cutting there stock one!) I may still decat mine someday, I want the bike to look and SOUND like stock, so if I do decat, ill still keep the muffler,but that will still plug up the exhaust. I've read that there is an old saying about exhaust, SMALL, POWERFUL, QUIET you can have 2 of the 3, but not all! Anyway the bike is running the strongest it has ever been with no air box lid and a jet "marked" 125. Plug still ashy grey, I have found a pilot jet kit and I ordered that from China, should be here next year sometime! I also added a digital volt meter, mounted it in a 35mm film container, and stuck it on the instrument cluster on the right side, looks GOOD. 8$ why not.
10-12-2020, 09:31 PM | #7 |
I would keep the stock setup. The biggest regret I have on the bike is the exhaust.
10-13-2020, 12:33 AM | #8 |
Hi browser, hi all, I'm thinking the same, keep the stock exhaust for now. It will probably rust out In 2 years anyway. If I still have the bike ill spring for the aftermarket exhaust, probably less expensive then stock replacement. I may have to sell it if I move, which will be probably out of state, don't know yet. One thing is if I move it won't be from long island to long island!
10-13-2020, 07:19 AM | #9 |
This is the crazy part, if they only had a little market pulse they would realize how many of the China Riders are sourcing parts from them, they could easily spec the bends for a Hawk \ TBR etc. and sell those pipes, keep a few in stock and market them as "bolt on ready"
11-09-2020, 10:00 PM | #10 |
Can anybody confirm that the TT250 header fits the exhaust port of a TBR7 ?..
It doesn’t matter if it fits anywhere else just the port. |
