It's the no-answer man back with more ???
Hi All, I got parts to add to the ATV (Rhino 250).
Winch LED Light Bar Oh and Anhound(SP) shift light setup. Now how do I wire all this into my factory battery? I am NOT an electrician or bike mechanic so any help needs to be somewhere around the 9 year old level of comprehension ![]() Additionally I am swapping out the 12T front sprocket with an 11T (JT) but I am not (and so that you do not spill it, please place your beer on the ground) sure if there is any fluids in the little spot these go into so before I jack mine all up is there? And a Huge thank you to this group for all you do for the riders out there! ![]() |
Winch;
http://www.chinariders.net/showthrea...ighlight=winch Sprocket and other info here; http://www.chinariders.net/showthrea...light=sprocket
The led light bar can wire to the battery as long as there isn’t a lighted switch that is lit in the off position as part of the setup.
The winch wires directly to the battery with the included wiring. If the winch has a wireless remote you should put a battery disconnect inline with the winch or it’ll drain the battery over time I never installed the shift indicator lights so I’m no help there. The neutral and reverse lights are enough for me. The front sprocket is outside of the engine. There’s no fluids to worry about. You will need to adjust the chain and fair warning, the adjusters on this bike are trash. |
