08-14-2020, 09:57 AM | #31 | |
08-14-2020, 04:24 PM | #33 |
What's even more dumb is the M27 or M28 thing doesn't matter. You need the M16x1.0 center piece to actually pull the flywheel on the Hawk, so as long as you find a puller with that thread size and pitch, you are good to go.
08-24-2020, 04:40 PM | #34 | |
$15 to the door. USPS
2017 RPS Hawk. Mikuni carb, 117.5 main, 25 pilot. Foam filter. NGK plug. Upgraded exhaust. 17/45 sprockets. Digital speedo. Full LED all around. U5 handlebar spot lights. 1982 Yamaha XJ1100 Maxim |
08-27-2020, 10:42 AM | #35 |
That's good to know Dan. I've never pulled the flywheel cover or flywheel off my Hawk. I assumed it would of been the same as the X22R. I'll need to order two flywheel keys.
08-30-2020, 07:12 PM | #36 |
Wrapped up my timing key install today.
Bikes running rich, but you can indeed feel better throttle response and a bit more pep in her. Overall an easy job and well worth it. I think it chalks up to not accurate sizing, but I was running spot on fuel mix on the stock carb, this vm26 clone must have a TRUE 40 pilot, which is larger than the so-called k40a pilot that's on the stock carb. Looks like I'll be buying a pilot jet assortment now. I can't dial my idle mix lean enough on this jet. Air/fuel screw all the way in or out, anywhere in between just isn't right. But I do like the 4 degree timing advance. |
08-30-2020, 09:51 PM | #37 |
I went to the local auto parts store and just bought a grade 8 bolt, and ground about 3/8th of an inch off the end of the threads. Then just thread it into the end of the flywheel and use the bolt to press off the flywheel. It works an absolute treat.
09-01-2020, 12:09 PM | #38 |
Well yesterday we installed a 12 tooth sprocket on Jay's Hawk and now you can really tell the benefit of the 4° flywheel key. 12/33 was the best ratio for my Hawk and netted 66mph. Because Jay weighs 120lbs less we thought a 13/33 ratio would be better for him. This was apparently not the case. His 5th gear was power assisted coasting.
But anywho, his bike is flying through the gears now and accelerates much faster. His top speed is still limited to 66mph, but I think it will have to have head work to cross that barrier.
09-02-2020, 11:04 AM | #39 | |
01-21-2021, 10:17 PM | #40 | |
05-01-2022, 04:35 AM | #41 |
I know this is the dual sport section, but this is the thread for this, so I figured it best to ask here instead of a new thread.
Will this 4 degree key work with the engines that come on the grom clones? |
05-05-2022, 09:55 AM | #42 | |
This specific key likely (probably) won't fit the crank and flywheel on those engines. This concept very well may... but getting an aftermarket CDI or one with variable timing is much easier. There are a few CDI boxes out there for those engines that allow you to jumper certain connections to vary the timing configuration. |
05-05-2022, 07:17 PM | #43 |
Why 4 degrees?
If 4 degrees causes kickback, why not try 3 degrees, or 2 degrees? It would still improve performance.
I know, the key isn't available, but a less radical key could be ground on the protruding side on a 4 degree key. You can then shim the shim on the side that is recessed with sheet metal. Viola, 2.7 degrees, or 3.1 degrees. Additional performance is great, but 4 degrees is arbitrary! |
05-15-2022, 03:03 PM | #44 |
I'm having a hard time finding the 4 degree key. Anybody knows who has it in stock? Didn't see it at Henner Motorsports today.
Thanks in advance. TORKER. |
05-15-2022, 04:43 PM | #45 |
0There are currently none to be had anywhere. Likely a shortage issue. Who knows when we will get more again.
