08-20-2020, 04:50 PM | #1 |
TaoTao T125 ATV - Questions/Comments
I bought a new T125 locally for my daughter. So far I've done the following to correct some weirdness and based on recommendations:
Lubricated the front brake cable so the brake lever would return to its released position Re-torqued the rear axle nuts to stop a persistent popping noise. Realized that you get what you pay for. Changed the spark plug Changed the front sprocket to a 10T so it'll climb our hills. She has now burned through a few tanks of fuel with minimal issues, however it tends to die when she lets off the throttle while in gear. Is there something I can do to fix this? If I raise the idle speed it shifts pretty hard. I'd rather not solve it that way. Also I just changed the oil and though I was told to add .75 quarts of oil, that seems to have put it over the "full" mark. Am I not getting it all drained or was I told wrong? Thanks Last edited by Virtual_Rider; 08-21-2020 at 09:48 AM. |
