07-24-2020, 04:00 AM | #1 |
TBR7 chain tensioner plate
Went for a long ride today and had some problems with the chain tensioning system. Chain jumped a few time and then the chain fell off a few times. It seems the plate (pictured) crushed in a bit and produced excessive slack in the chain. Has anyone else had a problem with the plate crushing inward? Seems like the "plate" is made of some sort of weak chinesium. I thought I could just cut some mild steel 1/8" and replace. Thanks for any advise.
2019 TBR7 2008 Baja Dirt Runner 125 2006 Honda XR100R |
07-26-2020, 09:16 AM | #3 |
i have taken apart that tensioning system and it looks like the plate needs to be flipped over.... is all....probably the manufacturer put it on backwards....it is a chinese bike after all ....
the washer idea sounds like it could work too if you need more tension.......i have had my stock chain stretch and jump off.... but i need to adjust it properly.... my guess is that loose chains fall off, ones that are too tight could break.
chain tensioner tbr7 |
