#16 |
I'm going to try the gasket thing Dan mentioned before I go all crazy on my head. Is the below J-B Weld 31314 Red Silicone Gasket Maker the right stuff to use for that?
https://www.amazon.com/gp/product/B00ID8IUJY And the below gasket from CSC? https://store.cscmotorcycles.com/TT2...p/zt41-100.htm |
#17 |
Lay a strait end across the head and pick a point to take a measurement. Keep checking the measurement as you sand it down until you removed the amount you want. I have a wright up some where on here.
#18 | |
#19 | |
#20 |
Nope, don't use the red stuff, it's not designed to constrain that sort of pressure. Also, it tends to fragment and clog up oil passages/pumps. If you don't use gaskets, you'll either need perfectly (re)machined surfaces on a Chinese motor, or you'll leak oil. You definitely need a head gasket, too. You'll potentially need shorter pushrods to. Just listen to Dan.
