Old 06-24-2020, 03:01 AM   #16
CaesarVis   CaesarVis is offline
I'm going to try the gasket thing Dan mentioned before I go all crazy on my head. Is the below J-B Weld 31314 Red Silicone Gasket Maker the right stuff to use for that?
https://www.amazon.com/gp/product/B00ID8IUJY
And the below gasket from CSC?
https://store.cscmotorcycles.com/TT2...p/zt41-100.htm
Old 06-24-2020, 08:56 AM   #17
Originally Posted by CaesarVis View Post
How do you keep track of how much material needs to be removed and how much has been removed? That seems like it would be the trickiest part.
Lay a strait end across the head and pick a point to take a measurement. Keep checking the measurement as you sand it down until you removed the amount you want. I have a wright up some where on here.
Old 06-24-2020, 03:23 PM   #18
Honestly, I don't recommend it. The headgasket is going to be good for a small bump and a little extra power, but leave the base gasket alone. If you must do it, don't use red RTV. Use something like Hondabond HT or Permatex Ultra Grey https://www.amazon.com/Permatex-8219.../dp/B000HBGI8K
Old 06-24-2020, 03:32 PM   #19
Is the red stuff too "permanent" or something? I was thinking about trying to replace both bottom and top gaskets with this stuff. I even saw some people on other posts claiming they don't use gaskets AT ALL!
Old 06-24-2020, 03:53 PM   #20
franque   franque is offline
Nope, don't use the red stuff, it's not designed to constrain that sort of pressure. Also, it tends to fragment and clog up oil passages/pumps. If you don't use gaskets, you'll either need perfectly (re)machined surfaces on a Chinese motor, or you'll leak oil. You definitely need a head gasket, too. You'll potentially need shorter pushrods to. Just listen to Dan.
