06-06-2020, 01:10 PM | #1 |
Chain Tention
Having issues with the chain coming off. I've been tighten by putting an old Philips in the hole and using leverage, busted my knuckles. There got to be a easier way right?
[IMG]Gy6 utility ATV by ntrodriguez, on Flickr[/IMG] |
06-06-2020, 10:16 PM | #4 |
06-06-2020, 10:19 PM | #5 | |
[IMG]ATV rear tension by ntrodriguez, on Flickr[/IMG] |
06-07-2020, 04:51 PM | #6 |
You can grease/clean the surfaces that rotate when tensioning the chain, that'll help.
06-08-2020, 07:24 PM | #7 |
The change in bolts seems to be holding, no dropped chain on yesterday ride.
06-16-2020, 10:45 AM | #8 |
On a Rhino 250, how do you loosen or tighten the front two nuts on the adjustment. I do not have a tool that I can get on them, no room. I just ordered a crows foot open ended wrench set. Hope this works. What do you guys use? My new chain now needs tightening.
2020 Toa Motor Rhino 250, two inch Rear wheel spacers, NGK Spark plug, More upgrades to come! Last edited by VeeVee; 06-16-2020 at 11:55 AM. |
06-23-2020, 02:45 AM | #9 |
IIRC for the Rhino style tension screws. I had to remove a couple of the bolts that hold the rear end to the frame. Then i was able to get a wrench to fit, its been a while since i done it.
06-23-2020, 02:45 PM | #10 |
Vm, The crow's foot was the deal. Got a set on Amazon and was in my hand in two days. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Made it into a pie job! Never had a set till now. Problem solved.
2020 Toa Motor Rhino 250, two inch Rear wheel spacers, NGK Spark plug, More upgrades to come! |
06-23-2020, 03:52 PM | #11 | |
