greetings from canada
After riding on the street for many years, I sold my beloved Buell S 1, and decided to ride in the dirt. Bought a sadly neglected 2011 Gio. It is basically sound just needs some TLC. Looking for a clutch cable from Canada (border is closed) No luck so far. Does anyone know where I can buy one? Thanks in advance, Harmon.
I'm not Canadian, but if you can get your hands on a Venhill kit you could always build your own. Just need to be able to solder one of the ends on. Kit U01-1-100-BK should do the trick.
Otherwise, you could give Venom Motorsports a call as they are based on both sides of the border. They might be able to help sort you out with a clutch cable that would work.
gio clutch cable
Thanks Megadan, I'll look into it.
You can also try member flashlightboy ,as he is a dealer for Gio .
Welcome!
