#241 | |
I don’t do high performance riding anyway. But, I will go ahead and order a new one too. I guess I need to start researching tires.
2019 Venom X22R K&N pod air filter, removed cat, 105 main jet, 36 tooth rear sprocket, RK racing 428 chain, oil cooler, NGK plug, bar risers, aftermarket mirrors, Grab On grip covers, phone mount/charger, Pro Grip tank protector, Chase Harper tank, tail, and saddle bags. |
#242 |
Your only choice in a 140/60-17 tire is the Shinko 006 Podium Radial. You will have to go a little wider or narrower to find any other brand besides the stock Chinese tire.
#243 | |
Speaking of... we could gear the bike taller by getting a taller sidewall on the rear tire. I don’t know if that’s something people regularly do on motorcycles.
#244 |
You can do that, but it's also possible to change the handling quite a bit, too, as it'll effectively decrease trail by effectively decreasing steering rake. It'll make for twitchier handling if you change it too radically.
#245 | |
#246 |
OOPPSS, I see your exhaust is done, didn't read far enough into the thread before shooting my mouth off. my mamma warned me about that.
#247 |
Ina Ditch, I appreciate your offer, but I did get the cat out and the amateur welds are holding up so far.
Jerry, I meant to mention that while it may be placebo, the bike felt smoother than ever after adding those balancing beads. I was cruising along at around 65, not even thinking about the beads, and just thinking how good the bike felt. I felt like I was going slower than I really was and then remembered I added those beads. So, they might be worth a shot. I figured for $18, I’d go for it. The key to getting them in is to fill the plastic tube halfway and then blow them in. But, the condensation from your breath will start clogging the tube so you have to wait 15-20 seconds between applications to get them to go in smoothly.
#248 |
not a problem, glad you got it done. I'm amateur to so you probably did as well as I could have I just didn't read far enough to realize you had a machine. I am enjoying this thread!!!
#249 |
Who doesn’t like pictures?!? I cleaned it up a little and tried to take a few decent ones.
#250 | |
