04-02-2020, 02:17 PM | #1 |
Plastic polish
I had a small scratch on a side pannel. Wet sanded it out to 2000 Grit and I cant seam to bring out the factory shine with anything I've tryed. I do have a 7" car buffer to use and paint is not a good solution. Does anyone have a good product to use.
Meguiar's mirror glaze 7 is so-so Meguira's PlastX no effect. Meguira's Deepcrystal polish no effect. Brasso NO Toothpaste NO Mothers wax NO Boiled linseed oil / Paint thinner NO Heat Gun NO
04-02-2020, 02:44 PM | #2 |
Man did you mess up. lol I did the same thing on my Hawk when i first got it. I could't get it to shine again either. I ended up shooting it with clear. I never tried that again.
04-02-2020, 02:45 PM | #3 |
If you can find it (seems to be sold out most places currently), this stuff works great. At least it worked for me to restore years-in-the-sun UV damaged black plastic on some of my older bikes.
https://www.carguysdetail.com/produc...32541917839448 |
04-02-2020, 06:27 PM | #4 |
I’m almost convinced the color is molded in but the high shine comes from a gloss overcoat.
04-04-2020, 12:39 AM | #5 |
I use a buffing pad on the end of a drill for my visors. It removes 99% of the fine scratches. For lubricant I just use dish soap.
Bashan Storm: Ebay steel exhaust wrapped, folding shift lever, seat mod, vm26 carb, air pod, dual led scrambler headlamps, windshield mod, led brake/tail light, secondary led brake light (swingarm), Ebay 295mm rear shock, back up CDI (racing unknown), oil cooler, digital gauge cluster, |
