Adjusting brozz carb
Hi all,
Just installed a new exhaust and deleted the restrictive snorkel on the air box on my 18’ brozz 250....I live in nj, should I adjust my carb and/or change the jetting with those changes? After warming the bike up and going for a ride I notice on heavy throttle is bogs down a bit then catches up. Guessing I need to adjust my fuel and rejet. Any advise will do, Thanks Update: Added a small washer under the needle and she runs much better now. Still has some low end power loss but I think rejetting it correctly will fix that. Last edited by Taylor250; 03-18-2020 at 08:27 PM. |
MotoCheez has a great carb tutorial.
If under 1000 ft, probably best to go up a size. He used a 115. I had Tennessee customer (unsure elevation) say 115 was about right as well.
www.Brozz250.com Email: jeffreyp@peacesports.com Phone: 770-662-1898 x107 Facebook: "Peace Sports" IG: Peace_Sports_Atlanta Youtube: "Peace Industry Group" |
The exhaust will almost always require at least jetting up on the main. A 110, 112, or 115 main with intake and exhaust is usually the ticket on most of these bikes, depending on elevation. I would say start with a 115, because it's always better to be a bit rich than a bit lean.
#4 | |
P.s. I added the washer on needle and the bike runs great other then some power loss down low. I think proper jetting will fix that tho.
2018 Brozz 250 blue eagle. Pro taper bars, Acerbis hand guards, integrated taillight, LED headlight, Dirt tires, NGK spark plug, crf230 exhaust, Removed air box snorkel. |
Thanks!
Also curious about this. What types of exhaust systems are usually used on this bike? Is the stock fine with some jetting at the carb? And like Taylor asked, where do people usually pick up their jets from?
#7 | |
I personally recommend OEM jets if at all possible, but you can get these bikes running decent enough on the cheap jet kits that cost almost the same as one OEM jet. https://www.amazon.com/10pcs-Carbure...%2C226&sr=8-26 If you find that you can't get the bike to ever run right with the cheap jets, that is when the OEM or OEM Equivalent aftermarket jets will become more necessary. The biggest issue with the cheap jets is that they are not always sized correctly, or consistently.
