Hi risers for handlebars...
Just wondering how popular risers are on these dirt bikes. Recently ordered a set that are 1.2 inch in additional height. I might have gone higher but that might necessitate moving cables and the like which I'd rather not do. Figured this would be the least expensive way to find out if its a noticeable difference. I know the height could vary greatly depending on the size of the rider and personal preferences. In the scheme of things I'm just curious how many guys end up doing it vs letting them stock.
Interesting... no one has tried this. Even though there's obviously little interest I still may offer up a post after I've tried them. Maybe everyone is changing bars instead ?
There are a few members that have them installed. Megadan for sure has them installed on his Hawk.
Yep, riser adapters for my Renthal Fat bars. I don't have a good close up shot of them, but you can see them in this one clearly enough.
[IMG] ![]()
#5 | |
Nice setup by the way... ![]() |
#6 | |
On my hawkesque, i put a clone of a renthal handlebars, first no risers and i found out that without them, start button and other parts will hit the plastics of the tank. This are the ones i had. |
#7 | |
I have them adjusted to suit my height/build. A little bit forward of alignment with the forks and the bar ends parallel with the ground. Nothing hits, nothing needed changing.
