#303 |
Exhaust will gain a slight power boost, a carb, as well as a Zonshen ported head from CSC. Gearing, even before trying to add power, should get you some speed. There is not much to be gained from the engine itself (the head is relatively new), as most people with these thumpers have shown on the dual-sports section; carb, gearing, and exhaust to start.
#304 |
Culcun pretty much got it covered. Most of the mods would be the same as the Hawk and Brozz, etc.
#306 | |
#307 |
I think you will be fine with the 17 tooth. Most of these bikes come geared too low from the factory. What's the tooth count on the rear and rear tire size?
#308 |
A 16T ok I’ll start there, and jerryhawk I’m not sure what the rear is I’ll find out for ya ty !!!
#309 |
just looking at pictures of the bike it looks like the rear is anywhere from 42-45 tooth and with the 205/40-14 rear tire I would go with the 17 tooth. That will still be a low gear ratio compared to what most are running on the Hawks and similar.
#310 |
Here's a sprocket calculator. https://www.gearingcommander.com/ You can use the Hawk to start with as it has the same gears in the transmission. Most are running 17/45 sprockets to give you something to compare to. All you have to do is enter the correct tire and wheel size which yours is 205/40-14. I looked it up on Venom Motorsports site.
#311 |
How much of a top speed increase shall I expect by upgrading to a 17 T sprocket?
#312 |
About 13%, theoretically, assuming it has the power to pull the bigger sprocket.
#313 |
Not sure what your rear tooth count is but probably 5+ mph.
#314 |
I guess that’s better than none put me at 55 mph
#315 |
You can also swap to a smaller rear sprocket later if you need a little more top end speed. What rpms are you hitting at WOT? Are you hitting the rev limiter?
