02-03-2020, 02:59 PM | #17 | |
02-04-2020, 09:41 AM | #18 | |
02-04-2020, 07:04 PM | #19 |
This is why I literally purchased a replacement \ 2nd carb in parallel to buying my TBR
To tinker, have spare parts, confirm when something is wrong that it isnt the carb ( which it often can be ). Order a knock off mikuni from Amazon prime for $27 bucks and get it to your house in 2 days |
02-04-2020, 11:16 PM | #20 | |
02-05-2020, 03:46 AM | #21 |
Have you replaced the plug? Do that first, it'll be cheapest, and make sure you write down what you're doing, so you can keep track of what you've done/undone. Otherwise you're spending money chasing a problem that will hard to keep track of. Get the plug before the CDI.
02-05-2020, 06:57 AM | #22 |
Also, make sure that the coil has a good, clean, unpainted ground.
