Old 02-01-2020, 04:32 PM   #1
Cimolifam   Cimolifam is offline
Cimolifam's Avatar
My new TbR 7 will not start
Well I have everything ready to go on the bike but cannot get it to start. The battery has a full charge, the light turns on. You hit the starter and it tries to start but it will not. It sounds like it is not getting any gas or the like. I did do a oil change and put new oil in. Any ideas? Spark plug looks good. The spacing looks good. I am at a lost.
Old 02-01-2020, 04:39 PM   #2
AJboughtamoto   AJboughtamoto is offline
AJboughtamoto's Avatar
Is the fuel petcock turned to the on position?
2019 Brozz 250
1999 Gas Gas EC300
2003 ZX6R
1991 Voyager XII
Old 02-01-2020, 05:02 PM   #3
Cimolifam's Avatar
Yep. The hoses are hooked up also.
Old 02-01-2020, 05:43 PM   #4
Choke on?, And Killswitch set to the Run position?
2019 Brozz 250
1999 Gas Gas EC300
2003 ZX6R
1991 Voyager XII
Old 02-01-2020, 05:47 PM   #5
Cimolifam's Avatar
Choke on full and kill switch is set to on..
Old 02-01-2020, 05:58 PM   #6
Try half choke and no choke. My Brozz won't start on full choke
2019 Brozz 250
1999 Gas Gas EC300
2003 ZX6R
1991 Voyager XII
Old 02-01-2020, 06:06 PM   #7
herbie   herbie is offline
I don't know much about the Tbr, does it have a kickstand switch? If so pull the kickstand up and try it again.
2022 Venom KPR 200 Red- the fastest color
16t and 46t sprockets, NGK Iridium CPR8EAIX-9, aftermarket full exhaust system. Top speed 81GPS
2023 Venom SS3 KP mini 150– Nibbi carb, Nibbi air filter, aftermarket muffler, decat
2022 Venom Ghost chopper 250
1997 Honda GL1500 Goldwing
1978 Kawasaki KL250
https://youtube.com/@herbiesgarage681
Old 02-01-2020, 08:13 PM   #8
Cimolifam's Avatar
Thumbs Down
Yep and no luck.
Old 02-01-2020, 08:14 PM   #9
Cimolifam's Avatar
No kickstand switch. Tried it with the kick stand up also.
Old 02-01-2020, 08:40 PM   #10
Hrm, is the valve lash set? It really should start even if it's off but it starting can be much harder if the valves are tight. Just running down the checklist here, These engine are super basic if you've got spark and fuel there isn't much else.
2019 Brozz 250
1999 Gas Gas EC300
2003 ZX6R
1991 Voyager XII
Old 02-01-2020, 09:03 PM   #11
if you've got spark and fuel.
This
I would either pull the plug or use a spare plug , stick the plug into the cap and rest it against the head to ground it. Crank the engine to see if it sparks, if a good strong spark occurs then check the fuel. Open the drain screw on the carb and see if it runs gas out of the drain hose, that way you know fuel is making it to the bowl.
1978 Kawasaki KL250
Old 02-02-2020, 01:16 AM   #12
Cimolifam's Avatar
This
Checked this. I do have fuel coming out of the carb with the drain screw turned. I did check the spark and I do get a spark. When I try to start it I can feel the compression from the exhaust. I checked all the wiring from top to bottom. Everything is hooked up correctly. I rechecked the oil and that is right on spec. I have a older bike like this one with a 189 cc engine and I have torn that down and put it back together and did not have a problem. I tried the kick start also and that did not work. I wish the seats came off better. I checked the air box and the filter is good and there is no water or oil in the air box.
Old 02-02-2020, 08:32 AM   #13
I think the TBR7 has a resistor on the cap. Make sure the plug isn't a resistor plug. A couple of members had the same issue. You should use a non resistor plug with a resistor cap.
Old 02-02-2020, 09:28 AM   #14
We had a small member group ride in Arizona in November. One member was on a TBR7 and started having starting issues when we stopped. It was revealed he did have the wrong spark plug but also, days later, since no one had the same kind to trade out and diagnose on the trail, the CDI was bad. It is a relatively cheap fix; ebay or amazon should have them. I believe I have seen that Tao bike owners (including scooters) have been diagnosing CDI units more so than others.
Old 02-02-2020, 10:12 AM   #15
Bruces   Bruces is online now
He says he has spark .
