Old 12-27-2019, 09:55 AM   #16
Sport Rider's Avatar
the sidecar will be no where near as complicated as the suspension and other things you did. it's really quite simple. AFAIK the angle of the hub is 0 degrees. when you connect the sidecar to the bike, you should have it angled in about 7/8 inch over a 6 foot length. I used a laser aligned along a 2x4 which was put against the rear wheel. I made marks on the garage floor in front of and behind the bike. when I attached the sidecar, I did similar markings based on the sidecar wheel. you want the front mark distance to be slightly less than the rear. in essence, toe in.
when you set up the sidecar to the bike, have the hub of the sidecar ahead of the hub of the rear wheel. on a shorter bike like the 250, perhaps start with 5 inches ahead. you can always adjust based on how it feels. the thing to remember with sidecars is it's as much an art as it is a science. tinker until it feels right to you.
Old 12-27-2019, 10:00 AM   #17
paulsstag   paulsstag is offline
Originally Posted by pete View Post
lead is how far the sidecar wheel axle is forward of the bikes rear axle....
Thanks Pete.
Old 12-27-2019, 10:05 AM   #18
Good info, Thankyou.
Ps i did PM you.
Old 12-27-2019, 10:08 AM   #19
Member Wamey had install a sidecar on his Hawk. http://www.chinariders.net/showthrea...hlight=sidecar
Video https://www.facebook.com/wamey/video...5174836991394/
Old 12-27-2019, 10:41 AM   #20
good find Jerry!
One other thing to note. finding a small used sidecar might be a good way to save a bunch of fabrication time. food for thought.
Old 12-27-2019, 03:12 PM   #21
OMG, that is just the kind of link i was looking for, Jerry your the best
I do believe , if it's still available, that a Velorex mount kit would shorten my fabrication time and frustration level . I'm thinking about a plate or bar with the lower tie ins that i can attach to the lower engine cradle area.
Question now is can i just pivot the sidecar at the bottom mounts and make it a leaner ?, put the bike on the side stand and maybe a stopper of sorts ( R/H) so the bike can just lean in towards the side car on the stopper ? or is that now over simplifying this? If this is doable then do you slow the leaning with a basic shock absorber ( which if the right length can act as the stopper in both directions?
Nice link Jerry
Thanks again
Paul
Old 12-27-2019, 03:24 PM   #22
Ebay has mounting kits. https://www.ebay.com/itm/UNIVERSAL-S...e1e7dbb9cc30c4
Old 12-27-2019, 03:27 PM   #23
good find Jerry!
I've been looking on Craigslist and so far i've seen only one ( Tucson AZ )(close enough to make it worth while to fetch ) (200 mile radius ) but it was $1500 which , like many here, is 10x what i would like to pay
China riders are a resourceful bunch so if any one has a lead that i did not dig deep enough to find please let me know . I live in Silver City NM 88061 and if i up my radius to 250 miles i think that puts me in range for Phoenix AZ , El Paso TX and Albuquerque NM .
Old 12-27-2019, 03:33 PM   #24
Now i know why they pay you the good money Jerry
Its time for a raise too
Old 12-27-2019, 03:46 PM   #25
Wait!! I'm suppose to get paid? I need to talk to upper management.
Old 01-02-2020, 01:06 PM   #26
Goob   Goob is offline
Hello,
I want a "sidecar", but not for animal or luggage. I want to basically have it as an outrigger so I can ride during the winter in snow. I try to ride to work everyday and missed 2 days last month because of snow. This place has something like I want for a Grom, but I would want a larger diameter wheel (I think) capable of what is typically my top speed on the commute of 50 mph. https://industrialmoto.com/utilitysidecars/
Goob
Old 01-03-2020, 08:06 AM   #27
Its_not_a_honda   Its_not_a_honda is offline
Just for ideas
https://www.ebay.com/itm/2019-Honda-...c69a%7Ciid%3A1
2020 Kawasaki KLX300R, 2018 Yamaha TW200
If you want more of something, tax it less. If you want less of something, tax it more.
Old 01-04-2020, 06:06 PM   #28
jerry i had forgot to give you your yearly 50% raise but consider it done now! your next check will be for 50% more than you are getting now.
thanks...
management
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
