rear brake caliper recessed screws purpose hawk
HAwk 250 :What is the purpose of the recessed screws in the rear brake caliper? there are two
I'm having issues with rear brake being total crap , have a new master cylinder on the way but if anyone knows the purpose of these screws and if they require various adjustments, i would appreciate it. Right now they are pretty much screwed in all the way and tight. MAybe they hold the caliper together, beats me. |
Are you referring to the two allen head screws? If so, those are the pins that hold the brake pads in place.
Here's a brake tutorial for the CSC TT250 which is the same as the Hawk 250. https://www.cscmotorcycles.com/check...ke-maintenance
