Old 12-18-2019, 09:25 AM   #1
Tylor_is_Here   Tylor_is_Here is offline
Zongshen Sierra ZS200GY-2 help!!!
Hello All,
I’ve recently come to own the frame and wheels of an 06 Zongshen Sierra. While she still needs work, I’m having a tough time finding a motor for her in the United States! Can someone help me, please? Any information on the motor, similar useable engines, anything! Thank you!
-Tylor
Old 12-18-2019, 09:50 AM   #2
Welcome aboard! You can find 200cc and 250cc engines on ebay.https://www.ebay.com/itm/LIFAN-200CC...AAAOxyOalTYZ1o
One our sponsors Brozz250.com have the counterbalanced cg250's for a real good price and have any engine parts you need for that engine available in the US. Use Coupon Code: "ChinaRider" 5% off any size purchase. Sale good December 06, 2019 to January 03, 2020
https://shop.brozz250.com/eshopprod_...e_Assembly.htm
2020 Kawasaki Vulcan S
Old 12-18-2019, 10:17 AM   #3
JerryHawk250 this will fit the frame of the bike? That’s my concern is that I’ll get the same size motor and it doesn’t fit.
Old 12-18-2019, 10:37 AM   #4
We have a member that did the Lifan 200 swap a while back. If I remember he had to modify the front engine mount a little to make it work. I'll try to find the thread and post a link.
The Brozz counterbalance engine will probably need a custom made front mount to make work. If you have some fabrication skills that would be the one I would go with.
Old 12-18-2019, 11:03 AM   #5
If you find that thread do let me know! I wouldn’t mind getting a readily available motor.
Old 12-18-2019, 11:45 AM   #6
franque   franque is offline
Either that, or you can swap in a Yamaha xt225 motor. The TW200 would fit, but the countershaft is a bit long.
Old 12-18-2019, 11:49 AM   #7
I did locate the thread but no point in posting it. All the pictures were deleted and no real write up to explain on what was done.
Old 12-18-2019, 12:31 PM   #8
Welcome, Tylor! X2 on the XT225 motor. It has more displacement, an OHC, more power and six gears. Total win.
Old 12-18-2019, 01:55 PM   #9
Weldangrind, I’ll look into it. I’m all for doing a little fab work if it doesn’t fit!
Old 12-18-2019, 05:05 PM   #10
NzBrakelathes's Avatar
It is a TW200 copy engine 100% ( double check ouitput shaft isn't miles out and the ZS doesn't have a decomp lever
I had this bike me self and sold it recently
Old 12-18-2019, 10:01 PM   #11
Okay, so in the knowledge of everyone present, would you say the Lifan is a worthy resemblance of the motor? I found some possible Zongshen 167FML series motors on this Alibaba website, but I don’t trust it. I’d rather stick to EBay where in the States I know I’ll be okay if it’s a scam. Lifan seems to be the popular eBay ticket. Is it worth it?
Old 12-18-2019, 10:20 PM   #12
And also, does anyone have a link to where I can purchase cosmetic parts for the bike? Like the rear light housing, fairings, hamdguards, etc.?
Thank you all so much for your help!
Old 12-18-2019, 11:12 PM   #13
These used literal clones of the Yamaha TW200 engine as others mentioned, if you can find one for a reasonable price. I think Chinese Hondoid (nicknamed that because they are not really identical to any real Honda engines, but are similar) are good alternatives; very reliable! Lifan or Zongshen will do the trick. Personally, I would go with a Lifan engine, but that is personal opinion, and not based on anything--in the end, either one will do the trick.
Old 12-19-2019, 11:38 AM   #14
Like Franque said, the TW200 countershaft is too long, so it's not a candidate. The XT225 or the TT-R230 is a good fit. You could also pop in a Yamaha Exciter 185 engine, although that's a five speed and has less power.
Bottom line is that the Sierra was designed for a Yamaha engine, not a Honda engine. Yes, you can fit a Lifan Honda clone engine in the space with some welding and grinding, but it's not a bolt-in deal. The original engine in your Sierra was a Zongshen ZS200GY-2, which is a near-perfect Yamaha clone. There is a ton of good info here: http://www.chinariders.net/showthread.php?t=6051
Old 12-19-2019, 03:55 PM   #15
david3921   david3921 is online now
Spud would have chimed in here but we haven't heard from him in awhile.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
zongshen, zongshen 2006, zs167fml
