Old 09-21-2019, 07:07 PM   #1
alex_in_az   alex_in_az is offline
what does this pipe do?
coming off the exhaust and running up to the area under the tank? some kind of emissions gear?
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
4 degree advance key
290 degree cam
Nibbi PE30 and cone filter
Front fork brace
Old 09-21-2019, 07:39 PM   #2
NzBrakelathes's Avatar
Remove and blank off
It’s air injection n useless
I’ll include a blanking plate with your soeedi
Old 09-21-2019, 07:48 PM   #3
Originally Posted by jeffrey View Post
He cant use the blanking plate. His is welded to the head pipe.
Ok then an angle grinder cut it off n weld a washer in place to blank it off
Old 09-21-2019, 10:11 PM   #4
AresROC   AresROC is offline
AresROC's Avatar
Is that an upgraded ignition spark coil? I want THAT!
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D
JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair .
Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2
BSR Chronicles - "Project leads to more projects!"
Yamaha WR250R
Suzuki GSX-R 600
Old 09-21-2019, 10:23 PM   #5
That will do it.
I've got an aftermarket pipe to replace the whole lot
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
290 degree cam
Front fork brace
Old 09-21-2019, 10:23 PM   #6
That's what it came with
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
290 degree cam
Front fork brace
Old 09-21-2019, 11:25 PM   #7
OneLeggedRider   OneLeggedRider is offline
OneLeggedRider's Avatar
On the TBR7 it's an air "injection" system that lets fresh air into the pipe to help burn off hydrocarbons as they enter the catalytic converter. All it consists of is a one way valve that works off of exhaust pulses. The other end literally goes nowhere, not to the airbox or intake manifold, just a filter up under the tank. Feel free to cut it off and patch/weld the hole. Or do the smart thing and get an aftermarket exhaust.
