#16 |
They are from a 2016 and all the yrs are the same.
2018 BD125-8-x21rs ZS190/Genuine PE28 Kepspeed GP1 Exhaust Protaper se x110 bars/grips 1/4 MotionPro throttle Kepspeed Braced swingarm Chimera rear hub assy Grom Intergrated tail light Superlite Sprockets 17/32 custom made from Japan Chimera Swing Arm Bolt RK MXZ Chain #420 All Balls wheel bearings Motodynamic fender eliminator Coremoto ss brake lines Composimo 2.5 lower link Grom Calipers-w/ebc pads/rotors Michelin tire 140&120 13x4/13x7 fatties Grom forks |
#17 |
Yesterday I'd asked a seller on Ebay if he'd mic a 2018 set and he replied with 39.5 and 41mm.
![]() No worries though. I think I have some 2014's lined up. Going to be great to get rid of those turd shocks for good.
BD125-15 |
#18 | |
#19 |
Did some asking around and someone said the 2014& 2015 are the same and 2016-2019 are the same but they said they have 2 different part# but ohlins has 1 kit for all yrs so if that's the case then mine must be from a 2015.
#21 |
Where did u get the steering bearings at? That's the one bearing I haven't replaced.
#23 |
Post pictures when done, I like seeing how others have made there bikes unique.
#24 | |
Also tried looking for an match with progressive suspension but; That is a complicated website to navigate through. ![]() |
#25 | |
The Nd4SPH (however you spell it) fork mod works on the 1st gen but not on the 2nd gen forks. |
#26 |
I looked for the Nd4SPH mod but was unable to locate anyone that had it or where to get it so I just went with the Race Tech springs .065. I have not installed yet but will be an improvement I'm sure.
#27 | |
https://www.hondagrom.net/forums/49-...ds-better.html This works only on the 1st gen Grom forks. For the second gen Grom forks... https://www.hondagrom.net/forums/7-g...orks-free.html In the two links, you can see how they're different. I have no idea how the Grom Clone forks are (I never opened mine up). Either way... I think swapping to the Grom forks like you did is the best option since it opens you up to the aftermarket fork internals. |
#28 | |
Gen 2 Grom preload on Boom Vader forks
Shush319 On the Honda Grom site 8/13/17. Explains his dilemma and what he found. I have a BD125/10 and appears to be near identical to the Gen 2 and so can do his mod to gain some preload. You see 1 shock in the normal position and the other has the approx. .5" threaded towards the cap. Hope this does it. I can't find my measuring cup. Anny idea how much in each fork is needed? |
#29 |
wlfpck Thanks for that write up, I was aware that it did consist of some hardware items but did not have a list to go by. Next yr when I get around to improving the forks I might try this along with new fork oil and the race Tech springs. Thanks again.
#30 | |
This is the part list that is for the 1st gen Grom to do that ND4sph mod. 2x - 59363-F - 1in Spacer (5/16ID - .469in OD - 1in Long) 4x - 3815-F - Neoprene washer (7/16ID - 1in OD) 2x - 43110-N - M8x50 1.25 pitch bolt 2x - 43893-E - Small M8 Washer The part numbers are from Hillman. |
