Old 06-09-2019, 03:39 PM   #196
Darth Racer's Avatar
Congrats on getting the stud out... feels good doesn't it.
Old 06-09-2019, 08:41 PM   #197
Fumblecopter   Fumblecopter is offline
Sure does...just have to order some new studs and I'm back in business.
Old 06-10-2019, 11:27 AM   #198
automatic transmission..
I do not know on th e larger atvs from TAO TAO.. but a lot of people have push started their auto clutch model... I did it once with a kids atv… surprised me.. that it started... one person with a 125 dune buggy with forward and reverse,... told me the starter when out and that is what they did to start it... too many times and he took the clutch out... but it started..
ABIBABA ATV ETC
Old 06-11-2019, 09:36 PM   #199
So, check out these Ebay studs...right size to work being an 8m 1.25 size and the part that goes a little further into the head. https://rover.ebay.com/rover/0/0/0?m...2F152292105577 My concern is the unthreaded part is 8mm...while the stock one is half that...I worry that is too wide. I can buy exhaust studs that are fully threaded at my local ace hardware...would that work? Also I can't find anything but nylon lock nuts...which I assume would just melt...would a lock washer or double nuts work?
Old 07-02-2019, 09:16 PM   #200
Here is the hole left in my frame from the lower motor mount breaking. More damage than I thought. Time to weld on a brace.
Old 07-02-2019, 09:17 PM   #201
I did end up using fully threaded studs from my local ace hardware. Exhaust with the new gasket is better than new.
Old 07-21-2019, 05:08 PM   #202
Broken motor mount
Finally rigged up my broken motor mount. Welded a half piece of pipe to the part that attaches to the engine. Had to grind off lots of the piece to make it fits basically over the cross brace and I did not weld it to the cross brace so it could move a little rather than be solid mounted. I temporarily used hose clamps to hold it in place until I put in actual clamps.
Old 07-27-2019, 12:46 PM   #203
BPizzle   BPizzle is offline
Originally Posted by ckangaroo70 View Post
Got mine today. Nice looking ride. I dove right in and put it together this evening. Went together pretty well. The foot Wells are kind of a pain to get the holes to line up but I wrestled with them and finally got them on. The only damage I could find on the whole ATV was there is a piece that is busted on one of the Wells. Nothing critical but probably will see if I can get that piece replaced.
I still have my winch to mount and my windshield as well.
More to come.....
Ckangaroo70, where’d you get the padded seat storage thing for the back? It looks like it fits great! I’ve bought and returned two cause they were too big. If you see this and can share that info I’d appreciate it! Thank u!!
Old 08-05-2019, 11:14 AM   #204
dugndeep   dugndeep is offline
Originally Posted by kpb View Post
Hey guys! Can anyone tell me if the GY6 engines on these Bull 200 ATV's are okay for water crossings. Seems like the cooling fan would suck in water/mud/debris and plug up the works after time. Any thoughts?
I was just wondering if part 19 would work on this engine to get your air intake snorkle up some,it comes on the 170cc snowmobile engine that also has a pull start as well as electric start.It's a GY6 engine on partskit website as well as the GY6 bull engine,probably be a direct swap if anyone was needing a new motor that has pull starting.https://partskit.com/product/engine?m=110967
You'd have to watch your left foot and not get into the pull start pulley unless there is a cover with pull start in it.
Old 08-05-2019, 03:41 PM   #205
Been thinking about getting a Bull or a Raptor for about a month now,just wondering who to buy it from.Also been looking to just see what kind of parts are available.I thought about the Rhino but if you get stuck it's going to be rough trying to clutch it and work the gas while off the atv trying to push or pull.Thought about buying from Txpowersports since I can use my Amazon account and make monthly payments there,so that's where I'm at.
Old 08-10-2019, 04:17 PM   #206
Pulled the trigger on the bull from Txpowersports.Was going to buy it from Q9powersports with Affirm financing but was told my 738 credit score was to low for full financing and would have to pay $700 down with the rest financed.I couldn't do that right at the moment so I went with option B which will cost a little more in interest but I'm okay with that.Affirm sent me a few emails wanting to know why I haven't completed my purchase.I sent them a email telling them I didn't have the $700 cash right at this moment.I just hope it goes thru and arrives in one piece.
Old 08-10-2019, 05:02 PM   #207
I got a quart of 20W50 full synthetic I run in my v-twin motorcycle and was wondering if it would be alright to run in the Bull after regular oil break-in?
I think I'm going to go ahead and get a quart of Royal Purple 10W30 engine break-in oil.Can't hurt I don't reckon.
Old 08-10-2019, 05:13 PM   #208
I did find this snorkle for the transmission cover from Hammerhead.https://hammerheadperformance.com/sn...-r-150cc-14322
Old 08-16-2019, 11:24 AM   #209
Mine arrived yesterday in excellent condition,surprised really.Now to get it put together.
Old 08-16-2019, 12:23 PM   #210
Douglass   Douglass is offline
Douglass's Avatar
I have been using Rotella 15w40 since it was new. I have about 28 hours on the ATV, and all seems good. I will admit that I drive it like it was stolen about 75% of the time. I also change the oil every few hours. The manual will have oil weight suggestions based on temp. Use this as a guide. Also, if you use to thick of an oil it may cause an issue with oil not properly lubricating the moving parts. Here where I am at temps are about 45-100 deg., but I usually wont run it to much when its in the 90s.
