06-13-2019, 03:49 PM | #1 |
bd125-8 Clutch
Just got my Venom bike and I noticed the clutch does not grab until its almost released. There is basically zero friction zone. Are there any adjustments for this? Does it change as it breaks in? I think I saw another post mentioned this but can't find it.
2019 Venom Motorsports X21RS 2012 Harley Davidson Sporster 72 |
06-13-2019, 07:03 PM | #3 |
Yeah I saw that adjuster and the one by the engine. Just wondering if there was some other adjustment I was missing.
06-13-2019, 10:34 PM | #4 |
U can also adjust clutch down by where
The cable connects to the clutch arm, make Your main adjustments here then fine tune at handle bars.
2018 BD125-8-x21rs ZS190/Genuine PE28 Kepspeed GP1 Exhaust Protaper se x110 bars/grips 1/4 MotionPro throttle Kepspeed Braced swingarm Chimera rear hub assy Grom Intergrated tail light Superlite Sprockets 17/32 custom made from Japan Chimera Swing Arm Bolt RK MXZ Chain #420 All Balls wheel bearings Motodynamic fender eliminator Coremoto ss brake lines Composimo 2.5 lower link Grom Calipers-w/ebc pads/rotors Michelin tire 140&120 13x4/13x7 fatties Grom forks |
06-14-2019, 01:26 AM | #5 |
On the right side of the motor there is a round cover
held on by two screws.. under that you will find the clutch thow cam and adjuster screw.. if that's not set right you can fiddle around with the cables all day and get nowhere... ..
06-17-2019, 06:36 PM | #6 |
I adjusted the cable till both adjustments were all the way in. It's slightly better now. Almost seems like the cable may be a tad bit too short. Going to check under the cover tomorrow.
06-18-2019, 01:55 PM | #7 | |
Check that the end of the cable going into the clutch arm on the motor is seated properly. I was having the same issue as you with my Hellcat, and after eyeballing the cable for a few hours and trying to adjust it, I noticed the metal bobbin that fits into the arm was not pushed all the way in. Once I did that I was able to adjust it to perfection. |
