Old 05-15-2019, 09:03 PM   #1
nij_tp   nij_tp is offline
help/advice needed Hawk Swing arm Zerk fitting
HI,
So next dumb question! I have drilled, taped and fitted a zerk to the steering neck tube, so hooray for my team. The issue I am having is that for the swing arm do I drill through the frame and then the metal tube inside that or is the grease suppose to go between the frame and tube (bushing)? I have removed the swing arm completely as I thought it might be the bolt I could see, but its not. So can someone confirm that I should keep drilling through the tube/bushing, as I assume the grease is to stop the bolt welding itself to the bushing, especially up here in the north.
Thanks in advance
Toys include Audi B7, running Stage 2+, S4 Brakes. My VW Vanagon is running 2.5l VVT Subaru engine, 18" AMG wheels, Porsche 944 Steering Wheel, W eekender interior. 1989 VW Vanagon Bluestar one of 2500, 1986 Honda Shadow, 2000 Suzuki Intruder, 1988 Kawasaki Voyager XII, 1976 Mercury Capri II, a bunch of Trailers including a shortened Vanagon for camping, a Sequoia and the latest addition a 2019 Hawk 250. (But dont tell the wife! ) (Latest latest addition a 1995 fwd Subaru SVX)
Old 05-19-2019, 09:48 PM   #2
I drilled through it all as it appears to be a bushing. I like Valvoline full synthetic with moly grease. Expensive but very slick!
Old 05-19-2019, 10:05 PM   #3
Thank you. I was just a tad wary of just drilling and not checking.
Old 05-20-2019, 10:00 AM   #4
Anybody thinking of how to tap the swing arm or Steering triple tree - At Home Depot you can get a #6 bit and M6X1.0 tap in a kit in the drill section. Drill it out and use the tap to put threads in the hole. Small crescent wrench will turn the tap, go slow and make sure the tap starts straight, perpendicular to the piece every few turns carefully reverse the tap one turn keeping it straight. Use a 6mmX1.0 short grease zert.
Old 05-21-2019, 02:27 PM   #5
Duggo   Duggo is offline
Post some pics? It's easy to do these days. Just attach a file with the paperclip. You don't have to go through the hassle of using photobucket or imgur. Just attach and post.
I don't know the vocab words, so I need pics.
Old 05-21-2019, 05:54 PM   #6
seems to me like the neck already had a hole that just needed threaded
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 05-21-2019, 06:12 PM   #7
It sure does. I had to plug one of the holes with a pop revit.
Old 05-21-2019, 09:02 PM   #8
dpl096   dpl096 is offline
dpl096's Avatar
Did you figure out what the original purpose of the hole was?
― Thomas Jefferson
Old 05-22-2019, 02:02 AM   #9
NzBrakelathes's Avatar
I’m sure they are rubber mounted and twist on the rubber bush
Don’t think geese will help but might harm
Old 05-22-2019, 06:35 AM   #10
Mudflap   Mudflap is offline
That's right. I pointed that out years ago. On the rubber bushing type you don't want grease. You want the steel tube inside the rubber to be clamped tight so it doesn't pivot.
Old 05-22-2019, 07:32 AM   #11
Originally Posted by jeffrey View Post
Vehicle information tag would be my guess.
^^^ What He Said^^^
Old 11-15-2021, 11:00 AM   #12
Tomkay44   Tomkay44 is offline
Then where shpuld we specifically put the fitting on the steering neck or should we even put a fitting there?
Old 11-15-2021, 11:03 AM   #13
I live near the Gulf Coast where Lousiana meets Texas. Am I safe using marine grade grease? That's what I bought for it.
Old 11-15-2021, 01:25 PM   #14
Originally Posted by Tomkay44 View Post
I live near the Gulf Coast where Louisiana meets Texas. Am I safe using marine grade grease? That's what I bought for it.
Marine grade grease would be you best option especially if you plan on any offroad riding where you will be going through water.
Old 11-15-2021, 02:03 PM   #15
Thanks for the answer JerryHawk250. I sure appreciate it.
