Old 05-19-2019, 09:54 AM   #31
goat67   goat67 is offline
goat67's Avatar
Great waiting to hear on how it feels. What weight oil are you using?
I need to do something as it really dips when braking right now.
2016 Brozz
Old 05-19-2019, 11:31 AM   #32
Duggo   Duggo is offline
Bashan Storm will take 300 ml of 15W fork oil. It's official, I've done it.
I'm not a good enough rider to tell you how it rides. I just bought the damned thing a week ago and have assembled it and changed the fluids and whatnot. I've got a grand total of 28 Km of riding experience.
Old 05-19-2019, 12:08 PM   #33
goat67's Avatar
Good to know, Good luck and have fun with it.
2016 Brozz
Old 05-19-2019, 12:14 PM   #34
Now, if it needs 300ml is a different question. the level of air gap left in a fork once you seal it back up will have an effect on how it rides. as the suspension compresses, so to does the air inside of it. The more it compresses, the firmer it gets - this is known as the air spring effect.
Let us known how it rides once you put some more distance on it. You don't need to be an experienced rider to make observations in simple terms.
Old 05-21-2019, 10:03 AM   #35
wedooit   wedooit is offline
wedooit's Avatar
How is the project coming along? Get it back together and on the road?
A family that works together, plays together, shoots and trains together, and sleds together, stays together. Second amendment! SkiDoo sleds, NOW 2 TTR225, and a BMS250. A couple of quotes (we are not farmers) "I don't get off the farm much" "Am too old school" I call the china bikes "the china syndrome".
Old 05-21-2019, 10:18 AM   #36
I got it back together, but it's been snowing and I haven't test ridden it yet. It snowed 3 inches last night.
Old 05-21-2019, 12:53 PM   #37
I did 250ml of synthetic atf fluid on my Storm. It changed nothing, the stock oil was nearly crystal clear and slightly thicker than the atf. I believe the brake reservoirs and forks were filled with the same quality dot 3 brake fluid. They are identical in every way.
Bashan Storm: Ebay steel exhaust wrapped, folding shift lever, seat mod, vm26 carb, air pod, dual led scrambler headlamps, windshield mod, led brake/tail light, secondary led brake light (swingarm), Ebay 295mm rear shock, back up CDI (racing unknown), oil cooler, digital gauge cluster,
Old 05-21-2019, 12:55 PM   #38
It’s been 85 here everyday. Mosquito heaven!
