04-29-2019, 03:40 PM | #1 |
Ac CDI or DC cdi
How do I know which CDI I have? I know it is a 5 wire.
Thanks |
04-29-2019, 05:28 PM | #2 |
Others will chime in on the technical stuff but I went on Amazon and found the exact connector(s) to the one I had to replace.
04-29-2019, 09:52 PM | #3 |
Did u get a performance CDI and did it make a difference? The technical stuff is pretty straight forward when I ended up on a better web page
04-29-2019, 11:02 PM | #4 |
Generally speaking if there are two wires attached to the two prong connector it’s an ac cdi ,and if there is only one wire it’s a dc cdi .If you can turn your headlight on without the engine running ,you have a dc system .There are exceptions but this is a good start to figuring it out
04-30-2019, 01:35 AM | #5 |
Sounds like DC
The 2 wire connector does it have a black only wire? That’s 12v DC with ignition on? If that wire is red n white then I’d expect a black n yellow with it Black n yellow is the coil wire red n yellow is AC with about 75v AC while running or cranking That info gives you enough to determine what you have |
04-30-2019, 08:46 AM | #6 |
My cdi has one white plastic clip with 6 available spots, 5 are filled with wires. I will do some testing tonight. I am going to hijack my own thread.......what is the tool called that stops the clutch from spinning? I am trying to remove the center bolt.
04-30-2019, 08:17 PM | #7 | |
https://www.amazon.com/Lumax-LX-1810...%2C199&sr=8-26 |
05-01-2019, 09:44 AM | #8 |
This part
Thanks for all the help
05-02-2019, 06:23 PM | #10 |
Ac/dc cdi
Check on youtube…. there is a good video on this.... the real test is... check the ignition wire and if the power goes off and on when you turn the ignition switch,.. then it is a dc cdi
