Old 04-29-2019, 08:17 AM   #1
Audihuff   Audihuff is offline
Audihuff's Avatar
rear sprockeet snapring
Has anybody have trouble getting the rear sprocket snap-ring back onto the shaft? I slighty bent it taking it off.. its on about 80% Will i be okay with out this? is the four "lug nuts" sufficient to hold sprocket on? Where can i get a new snapring? Thanks
To light a candle, is to cast a shadow..
Old 04-29-2019, 09:30 AM   #2
Alpha Reign   Alpha Reign is offline
Alpha Reign's Avatar
I use big ol snap ring pliers. My snap ring is slightly bent, not enough to make me worry though. I forget the size but you can get a pack of them at Grangers. I'll look for the sizing.
Hawk 250
Lithium Battery, Mikuni Carb 110 main jet, Bark Busters with Mirrors, Extended Mixture Screw, 428 O-ring Chain, 17-15/40 sprockets, Digital Cluster, Cycra YZ250F Skid Plate, Oil Cooler
Old 04-29-2019, 09:45 AM   #3
Do not ride it without the snap ring. That's what secures the sprocket in place. I would replace the snap ring if it is bent.
Old 04-29-2019, 10:14 AM   #4
blanc12   blanc12 is offline
Tap it into the grove with a punch and hammer. Make sure the tabs are close like they were when you took it off. If they are you should be all set.
That snap ring is the only thing keeping the 4 studs in the wheel. It must be seated correctly.
Old 04-29-2019, 08:27 PM   #5
NzBrakelathes's Avatar
MUST HAVE the ring so it doesn't fall apart, holds the sprocket in so it doesn't slide out!
Need some? I can get say 5-10 maybe this should be an item in my eBay store with studs?
Always looking for products that help solve issues etc
Old 04-29-2019, 08:38 PM   #6
The stock studs and nuts seem to be pretty soft. Are yours made of good steel?
Bashan Storm: Ebay steel exhaust wrapped, folding shift lever, seat mod, vm26 carb, air pod, dual led scrambler headlamps, windshield mod, led brake/tail light, secondary led brake light (swingarm), Ebay 295mm rear shock, back up CDI (racing unknown), oil cooler, digital gauge cluster,
Old 04-29-2019, 11:21 PM   #7
elkhunter338   elkhunter338 is offline
Hmm is the Hawk snap ring different than the tt250. The tt250 snap ring would only hold the sprocket on if the bolts sheared off, it does nothing under normal circumstances. I believe some leave the snap ring off with aftermarket rear sprockets and spacers.
I did not install spacers with my aftermarket sprocket and put the snap ring back on. Chain is lined up better with a straight sprocket without spacers. CSCtt250.
Old 04-30-2019, 01:10 AM   #8
Snap ring is likely the same, but the Hawk uses an old school Honda cush drive hub where the studs are simply pins that sit inside a metal sleeve of a rubber bushing. They do not secure it to the hub, but instead locate it and provide positive engagement to drive the wheel. The snap ring acts as a lateral retainer to keep it on the hub. The TT250 simple bolts the sprocket to the hub and the snap ring is there as a kind of backup retainer
Old 04-30-2019, 01:31 AM   #9
Who knows for real etc
There’s 2 grades but reality I can’t say
I’ve never broken studs but I have busted the bushes
I’ve also suggested maybe solid inserts and bolts as it’s stronger but then no fish drive affect
That’s how some MX bikes are in china
Also a version with bolt but rubber inserts
Old 04-30-2019, 12:36 PM   #10
Ok, I’m in the market for a full set this year. I’ve swapped the cog so many times the nuts are rounding off.
