Old 04-18-2019, 09:25 AM   #1
Alpha Reign   Alpha Reign is offline
Alpha Reign's Avatar
Oil cooler Working?
I just installed my oil cooler on my Hawk, i'll post pictures when I get home. But I'm not sure if oil is pumping through it. For one my gut is telling me its not, and for two the oil levels do not appear to go down when I let it run. Maybe I over filled it, but I went on a 30 minute ride yesterday and nothing seemed to happen. I check before, about 15 minutes into the ride, and after. I am going to check the valves and see if there is some oil left over in there. Is there a way I can check/fix this.
Thank You!
Hawk 250
Lithium Battery, Mikuni Carb 110 main jet, Bark Busters with Mirrors, Extended Mixture Screw, 428 O-ring Chain, 17-15/40 sprockets, Digital Cluster, Cycra YZ250F Skid Plate, Oil Cooler
Old 04-18-2019, 09:33 AM   #2
MAT   MAT is offline
MAT's Avatar
Did you verify nothing was plugged? I've seen new oil lines that were.
Piranha P190R mini-motard racer
20 Thumpstar TSX-190
12 Yamaha TTR-125 FT/ice racer
09 KTM 450 XC-F SM racer
75 CB400F Vintage rider
Old 04-18-2019, 09:55 AM   #3
Do you feel any heat coming off the cooler after riding? If so it is working. If it wasn't working you would of known a few minute of riding because it would of seized up. The oil will not drain back into the base because the pump acts as a check valve.
2020 Kawasaki Vulcan S
Old 04-18-2019, 10:21 AM   #4
That's the problem. I'm not feeling heat off the cooler or lines. I don't know how hot it should be, but I'm not feeling any. What about the oil levels not dropping?
Hawk 250
Old 04-18-2019, 10:47 AM   #5
Did you fill the cooler before hooking the line up? It may have some air in it. It's not going to get super hot.
Old 04-18-2019, 11:12 AM   #6
Yes, I filled it up before install the best I could. Is there a way to get the air out besides from unhooking it and trying again?
Hawk 250
Old 04-18-2019, 11:28 AM   #7
I think you are okay. What was the temperature when you were riding? I know on cold days (50s) my oil temps don't go above 140. In 80 degree weather( yes it has gotten that hot here already) the temps never gotten over 185.
Old 04-18-2019, 11:37 AM   #8
We had a few days in the 70s. I think it was around 67 yesterday. Thank you for the help! I appreciate it.
Hawk 250
Old 04-18-2019, 04:20 PM   #9
Red Hawk   Red Hawk is offline
Red Hawk's Avatar
Pull the valve cover and find the circular hole "film canister size" then pull the plug wire off and crank the starter over for about 20 seconds you should see the oil pump up the hole like it was going into the valve train. If you are in colder weather the lines get hotter then the radiator does till summer time.
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite!
