Taotao Rhino 250 valve lash specs
Title says it all what is the spec for valve lash on the rhino this is a 2013 rhino if that matters or not, thanks in advance
I believe most people set them at .003" and .004". I set .002" for both which is what the Lifan CG manual says.
thanks
Hi there ,
I’m still searching for a taotaorhino 250 service manual. Does anybody know where I can get my hands on one, or another model that uses the same engine? I have replaced The clutch but I’m getting no resistance when I manually try to move lever on side of crank case. Is seems like I’ve forgotten to replace a spacer to bring out the clutch plates to meet the pin that engages the clutch. Has anyone run into this problem? |
Or have access to the service manual so I can retrace my steps????
Thank you , John. |
Do a search for a factory service manual for a Honda CG125.
storm-english-62ktjam5.pdf
This is the one I downloaded several years ago. If there is a place to upload it to this site I'll be glad to do it. It's about 8.5 megs. |
https://josemaco.files.wordpress.com...h-62ktjam5.pdf
When I searched for the PDF name it actually pointed to a thread here at China Riders, with the link. That manual states 0.003 +/- 0.001 for exhaust and intake. |
#9 | |
