To light a candle, is to cast a shadow.. |
You could try to use a dremmel and make a slot so you can use a flat head screw driver.
Hawk 250 ![]() Lithium Battery, Mikuni Carb 110 main jet, Bark Busters with Mirrors, Extended Mixture Screw, 428 O-ring Chain, 17-15/40 sprockets, Digital Cluster, Cycra YZ250F Skid Plate, Oil Cooler |
the head is almost non existent at this point. this is the softest metal ive ever dealt with.
welp after looking further, it is not a normal machine screw. the tip of it is blunt as most of you know to raise the "slide throttle". left handed bit did not back it out.. an easy out snapped in half on me.. OH WELL its only a 30$ carb!
Check to see if the idle screw is the same from the stock carb.
#6 | |
that was my hopes, but i failed horribly to get it out haha ![]()
