03-07-2019, 09:21 PM | #16 |
Congrats Jeff on the new hawk. Now the real fun starts.
03-07-2019, 10:47 PM | #17 |
So far so good it's on its wheels now only issue is one of the handle bar mount bolts wants to cross thread I will clean it up with a tap tomorrow and I have to align the rear wheel and adjust the chain it is super tight. Gonna fill the battery so I can take it to get charged at lunch and call it a night.
03-09-2019, 06:28 AM | #19 |
Get some brake cleaner and clean up the oily film on the brake rotors too.
03-11-2019, 09:08 AM | #20 |
This thing is a blast ! Btw is the odometer in km because I don't think I rode it 90 miles already?
03-11-2019, 09:56 AM | #21 |
It's in km and even that's not that accurate.
03-11-2019, 11:41 AM | #22 |
It's a combination of km and the front wheel diameter. Mine has a 1.42 error - i.e. it reads 1.42x higher than actual mileage. I have no idea how consistent that would be across years and odometers.
Make a couple runs with a GPS to compare distances vs. the odometer and you'll be able to determine a ratio for yours. |
03-11-2019, 02:01 PM | #23 |
Got to get a phone mount then I can use GPS app . Any recommendations. And where is a good source of power for a 12v plug ?
03-11-2019, 07:09 PM | #24 |
Finely got some dirt under the tires
03-11-2019, 07:30 PM | #26 | |
https://www.ebay.com/itm/12V-Dual-US...kAAOSwcnJcGgB1 You'll have usb power wired to the headlight switch. So you won't kill your battery.
03-11-2019, 08:11 PM | #27 |
Awesome picture and good looking bike.
03-12-2019, 08:51 AM | #28 |
That's what I was thinking but that little light stays off unless the headlights are on
03-12-2019, 09:05 AM | #29 |
I had rewired my light to come on with the ignition like is should be. I also replaced the bulb with a bright LED.
03-12-2019, 03:59 PM | #30 |
Easiest way to get USB charger power is to put an SAE lead on the battery for a battery tender, and then buy one of a hundred options on Amazon for an SAE plugged handlebar mounted USB port. When you store the bike you can use that same SAE lead to plug into a battery tender, and it gives the lead something to do when not being stored.
