Old 03-04-2019, 06:31 PM   #1
SenselessOverloadi   SenselessOverloadi is offline
Raising RX3 (or how long are the different suspension linkage options?)
I've been riding a ludicrously overloaded RX3 (over 200kg of riders and luggage...) for around 10000 miles now and the constant bottoming out is starting to get to become an issue. By that i mean the airbox fasteners are very exposed and liable to come out at any time.
I think the best solution is to fit a longer and stronger shock. But, I'm not gonna do that. Instead i think i will get the drag link shortened. Could a vertically challenged individual who has bought the lowering kit be kind enough to measure how long their drag link is?
Old 03-05-2019, 10:12 AM   #2
I also emailed CSC and the answer is:
A 3/4" longer drag link drops the bike 1". I'll probably try and get the link shortened by around 1/2". I think making it much shorter than that could cause clearance issues.
Old 03-05-2019, 11:11 AM   #3
Vtrover   Vtrover is offline
drop link
i have a standard drop link which i would pass along to you if you need it, also i have for sale the upgraded tall seat for sale!
Old 03-05-2019, 11:43 AM   #4
Sorry mate I'm in the arse end of Patagonia, I'm just gonna remove the current (standard) drop link, chop it up and get someone to weld it.
Old 03-05-2019, 12:24 PM   #5
elevatorman   elevatorman is online now
tall seat
Hey, how much for the tall seat?
Old 03-05-2019, 12:56 PM   #6
seat
@elevatorman make me an offer? shipping at your expense!
Old 03-05-2019, 01:17 PM   #7
calvarez   calvarez is offline
If you are bottoming out and overloaded, the correct answer is a stronger spring with more shock damping, not changing the lengths of things. More preload might help also, but spring weight is based on load, and damping is based on both spring weight and load.
Old 03-05-2019, 01:18 PM   #8
rjmorel   rjmorel is offline
rjmorel's Avatar
Senseless, I take it you've already tightened up your preload on the rear shock? That's what I did to keep from bottoming when I'm loaded down. rj
Live Zong, and Prosper
Old 03-05-2019, 02:23 PM   #9
Yup well aware of how i should do it (as i said in the OP) but parts availability is not great here.
Already cranked up the preload, but used a rock and a screwdriver and now the preload adjuster is not in great shape. I could theory wind it further as there's more thread left on the pre-load adjuster, but I don't have the tools and its already pretty high.
Old 03-06-2019, 09:01 AM   #10
Orlando texas   Orlando texas is offline
I did the same adjust the spring tighter and put a little air in the valve and a aluminum plate where tire rubs works good we're always 2 people on bike and we're not light haha
