Where to buy an oil cooler?
I want to get an oil cooler for my Hawk. But I have no idea where to buy it from. I saw this link from jerry, but how long will shipping take? Also there are tons of buying options and I'm not sure which one to click. Are there any other places to buy cooler for a reasonable price? preferably under $50.
Hawk 250 ![]() Lithium Battery, Mikuni Carb 110 main jet, Bark Busters with Mirrors, Extended Mixture Screw, 428 O-ring Chain, 17-15/40 sprockets, Digital Cluster, Cycra YZ250F Skid Plate, Oil Cooler |
https://www.amazon.com/gp/aw/d/B07HK...mob_b_pd_title
This is the one i got bolted right up and i can definanetly tell a difference in engine temps |
#4 | |
Thank you all for the reply, I appreciate it. Now I got to figure out how to mount it.
None at all it came with everything including mounting clamps i even drove it through some deep mud and brush and took a high power pressure washer to it to clean it off everythings fine thise bad reviews are probably just from people who dont know what theyre doing or rushing through it honestly
#7 | |
#8 | |
#9 | |
Does anyone know how much extra oil you add to the system for this? And where can you get a replacement filter?
I changed the oil on mine over the weekend. With two coolers it took 1 quart and 4 oz. There is no need to replace the filter. It's just an oil screen that can be cleaned. That's to catch any large objects. The actual filter is the spinner filter that should be cleaned every few thousand miles. You will have to remove the clutch side cover to access it.
I have never heard of this. I would appreciate any info you could give on how to do it and what i would be looking for im still a ways off but i want to make sure im doing everything in my power to keep the bike running properly TIA
#13 |
First one is after it was abused a little bit lol
#14 |
Thanks for the pictures. It looks good. Have you had any problems with it moving or oil flow issues?
#15 |
None and i can definanetly tell a difference from the oil going into it and the oil coming out of it by feeling the lines easily 30 degrees cooler at least.
