01-09-2019, 03:27 PM | #1 |
TaoTao Rhino Engine
So I know the 50cc- 200cc engines are GY6 clones but what is the Rhino's engine a clone of looking for parts and don't know what to call it. Thanks.
Looking into adding kick start for a backup. |
01-09-2019, 03:52 PM | #2 |
The rhino has a CG200 engine based off the CG125 Honda.
01-16-2019, 06:14 PM | #3 |
ok so valve adjustment question.
So I removed the plug to see the top center T mark. I removed the side cover to access the bolt to rotate the flywheel counterclockwise stopping on the T the valves where super tight so loosened and set them to .002 I rotated the flywheel 3 times stopped on the T mark again and the valves are so very loose rotated it again stopping on the T mark its back at .002 so when should I set the valves when it is on the loose setting or tight setting? |
01-16-2019, 07:13 PM | #4 | |
01-18-2019, 11:05 AM | #6 |
will this fit the rhino?
https://www.ebay.com/itm/10x-Engine-...u3kU:rk:4:pf:1 |
01-18-2019, 03:37 PM | #7 |
You want to get an inline filter. The one you show isn't the right one or style.
