#31 | |
#32 | |
I didn't hone the cylinder it still had the factory honing and was without pitting or scratches from old piston, and the bike had no run time since it came dead.. It's looking like just giving TXPowersports $500.00 for a engine is the only solution since I don't have the home time a lot of people do and need to get this done and no shop will touch it.. I don't know of any test to find what is leaking oil into the chamber besides a leak-down test and that doesn't tell whether it's valve seals, rings, backflow, or head gasket just that there is a leak which I already know.. Would putting oil in cylinder help tell if it's rings or cylinder, or something else like Marvel Mystery Oil or something? |
#33 |
Before tearing into it again, I'd perform a couple of tests. See if you can borrow a compression tester from a local auto parts place and get a sense of what the compression is with the throttle wide open.
Also, see if you can borrow a leakdown tester. The simplest way is to use a hose that has the appropriate plug thread on one end and a compressor quick connect on the other. Thread it into the head, hook it up to a compressor and give it 100 pounds or so (with the engine at TDC, as if you were going to set the valves). Where do you hear air escaping? If it is out the crank vent, the ring seal is bad. If it is coming from the rocker area, either the valve guides or seals are bad (or both). If you don't hear any air coming out of the muffler or carb, your valves are sealing as they should. Were the rings pre-installed on the piston, or did you install them?
#34 | |
Leak test sounds promising but I have to source a compressor that can handle it.. I didn't know you could actually trace the problem by sound of air flow.. |
#35 |
It would be a bad leak if you can hear it. Keeping an eye on the pressure over time will be the thing to look for. Of course, no engine holds compression. It will leak down. If it leaks down in a few minutes, there's a problem. If it leaks down over hours and the compression is good, there are likely no problems.
Smoking after starting an engine that's been apart is common. You've been handling the parts with oily hands I bet. That oil could be in the pores of the castings and it's burning off. If it's exhaust smoke, it could be from the earlier problems. There may be oil coating the inside of the header and muffler. |
#36 | |
X2 on everything Ben just said.
#37 | |
#38 |
I will take it out on a back-road and try and smoke it out my next free day. My compressor has too small a tank and doesn't have the standard coupler the kits all use.
I've seen thicker oil and additives used to fix or detect bad rings and main bearings too. People use diesel oil to flip cars with bad engines.. |
#39 |
Hi
Why not buy a cylinder with piston set etc? I would rush out n buy another cheap brand engine If an engine is needed you got more choices if you extend the budget Other thing did you replace the O ring on the head bolts between the cylinder? I wonder if you didn’t break an oil ring? I think there are many more options or possibilities rather then rushing out to buy a cheap made non Zongshen engine |
#40 | |
If you're referring to the rubber ring on the block-stud back-right it's securely seated and not cracked or fatigued. The head and valves and piston and rings are new so I'm thinking of a new cylinder too. The one on it had no pits or scratches but I've pretty much eliminated valve seals, back-flow ring, and head gasket by taking it apart again and triple checking everything that can let oil in to the chamber with visual analysis. The base gasket and anything below cylinder section of head can't cause this so it's a very small area for the problem to exist.. It's basically down to cylinder, ring rotation(rings new at 180 degree rotated based on openings), head gasket(no visible defects orange seal not cracked), back-flow seal(like new+seated), and valve seals(new).. By the way I've had the engine apart a few times and never looked how that head backflow actually flows just that there is that seal and a slot under the stud-bolt&washer under the valve cover.. I didn't see and place for it to flow down the bolt on the bottom of the head though so I assume there is a channel inside the head going over to the pushrod part or it flows through the stud-sleeve.. Last edited by DualSport; 11-30-2018 at 02:56 PM. |
#41 |
Just wanted to close this thread out. The new rings RPS sent me through Q9 were too small.. I compared them to the old and used the old after realizing it and now no smoke.. I'm not sure what those rings go to but it's not a Hawk or Magician....
A few notes:
#42 |
Agreed that often basic parts are way over priced in the USA but they wanna make a quick buck!
I’m thinking of getting this bike as a tester but we will see Have a good New Years lad ![]() |
#43 |
Glad to hear it's not smoking anymore, DS. I hope you enjoy your new bike.
