#181 |
NZ, a good idea will be to post the cost on each item, just thinking, so we dont have to ask for each one.
Thanks for looking out on good stuff. |
#182 |
Still waiting for my wife to get her shipper number (requires her ID and they spy on her)
I sent 2 packages to SQWERT yesterday so I can post already but can't work out if they use our shipper number or they were nice and arranged it some other way. Epacket to the USA is $0.01 per gram + $2 each package (up to 1.99Kg) I might post the item prices today and an estimated shipping costs as shipping isn't expensive (assume $5 as a minimum and up to $20 for maximum) I do not hold parts in stock (not much unless fast moving or part of the 300 kits to cut out drama) so it takes a few days to get the items and I believe 2-4 weeks to the USA. But as always I can easily DHL stuff but much higher cost and usually at your door in the USA in 5-7 days |
#183 |
I have a pair of Tourefella bags in stock $35 each/$70 a pair and shipping is $18.50 which is only $1 more then the pair I posted while in the USA
So $88.50 posted from China to the USA and expect them to take 2-4 weeks to arrive. Last edited by NzBrakelathes; 12-13-2018 at 12:43 AM. |
#184 |
Large hand guards to keep the cold wind off your hands
This will keep the wind off your hands during these cold months.
![]() Assembling the extra screen was a bit fiddly and holes didn't perfectly line up - expect to drill them out, harware and allen keys included and I only used some new and some old from my weighted bar end - fitted nicely and easily but my brake master cylinder isn't the original and I will need to make a bracket as currently not correctly mounted yet fits in the right place. These are a universal fit I choose the dark color and dark shields - there are other color or clear options too. ![]() $25 plus $9.50 shipping if to the USA 0.750 Kg |
#185 |
Radiator overflow bottle upgrades
Here are the 2 upgrade bottles - the funky looking shape needs a minor mod and DIY see links below
This is a 100% direct replacement for the RX3 and has the rubber flip open lid. https://www.ebay.com/itm/303025898703 This is the RX3S version (might fit on inner guards on VERY late model) I mounted it from the bolt where the frame for front nose mounts and used an angle bracket to the coil bolt, some DIY needed but super easy to fill. https://www.ebay.com/itm/303025901309 http://chinariders.net/showthread.php?t=16308&page=8 http://chinariders.net/attachment.ph...1&d=1536316017 http://chinariders.net/attachment.ph...1&d=1536316017 Last edited by NzBrakelathes; 01-10-2019 at 11:20 PM. |
#186 |
Oil filters (paper or mesh large filter) for the RX3 or RX4 or any NC250 motor $15 for 2 including E packet cheap postage to the USA and possibly other places if shipping isn't wildly different.
I also have the small black filters and O ring sets for filter caps and sump plug washer kits add $5 http://chinariders.net/attachment.ph...1&d=1525825691 |
#187 |
Hi NZ, do you have complete gasket sets for the RX3?
#188 |
Can get
I don’t need to stock much as most is only a day or 2 from me away |
#189 |
You're selling the full hand guards, or just the little add-on shields? I do want to get hand guards, but not interested in the extra wing on top.
I got the small upgrade bottle from NZ, and it was pretty easy to install (had the plastic off anyway). Much easier to reach in and refill it now. BTW, an empty beer bottle make a good refill vessel for the task. Should I admit that there are always empty beer bottles in my garage...? |
#190 | |
Led version a bunch extra costs No wings small difference in price Also if you want to spend $80 ish there’s a good pair with heavy Allie L bracket with plastic attached or the basic set like in pic no Ali support just plastic but decent |
#191 |
Hmm, so many options. What I'd be looking for is something pretty tough, where I won't bust up a hand and/or levers when I go down in rocks. AZ is pretty rocky. Thoughts on the best choice?
#192 |
OK, what would be the cost to US, also can arrive before Dec 29th?
#193 | |
Send a list to my email - let me check up for you this weekend and yes it could be there before you get there etc |
#194 |
I'll take those bags if they are still available. I am in BC, Canada.
Farkles: CSC Skid Plate, Seat Concepts Low Seat, Genssi LED, Center Stand, USB/Cig Pwr, GPS mount, Spotlights, Sintered Brake Pad, 13T / 45T, Shinko 804/805, Side Stand Pad, Tourfella Luggage, Heated Grips, Sheepskin Gel pad, Progressive 465 Shock |
#195 | |
Email me tako@nzbrakelathes.com send your full address name phone number etc so I can esquire tomorrow. I normally don't stock all the things I sell as I can easily get parts within 3-4 days so the supply is always there, more bags no problem Last edited by NzBrakelathes; 12-17-2018 at 07:37 AM. |
